Secure my Collabora office
Hi, I currrently have the application installed on the same server as my nextcloud server in docker. this is the command I used:
docker run -t -d -p 192.168.1.182:9980:9980 -e “aliasgroup1=https://nextcloud.domain.online:443” --restart always collabora/code
how can I make sure that no one uses my office server domain located at: office.domain.online.
I have seen details about editing an xml file but how do I do that with a docker container image.
hii @djshades2004 welcome to the collabora online forum
To ensure that no one else uses your Collabora Office server (hosted at office.domain.online), you can secure it by restricting access to only your Nextcloud server. Here’s how:
  1. Alias Group Security:
    In your docker run command, you’ve already added the aliasgroup1 to allow only requests from https://nextcloud.domain.online. This is a good first step.
  2. Edit Security Settings in XML:
    To further restrict access, you’ll need to edit the coolwsd.xml configuration file. Since you’re using Docker:
    • Access the container:
      docker exec -it <container_name> bash
    • Locate the XML file (usually at /etc/coolwsd/coolwsd.xml) and make necessary changes.
  3. Forum Resources:
    These threads provide detailed steps to secure your server:
  4. Explore More Solutions:
    There are several other topics on the Collabora Online forums related to securing your setup. Explore the forums to discover more ways to restrict access and ensure a secure deployment.
https://forum.collaboraonline.com/search?q=secure
Thank you Darshan for your reply, I wondered what the aliasgroup statement did. Should this be enough for security?
Hi @djshades2004,
I hope you’re doing well!
To help you secure your environment, I recommend checking out the official documentation here:
Collabora Online Security Settings
It provides detailed guidance on setting up options to enhance the security of your deployment.
You can do quick additional things:
docker run -t -d -p 127.0.0.1:9980:9980 -e “aliasgroup1=https://nextcloud.domain.online:443” --restart always collabora/code
This binds to localhost. You will have to use your reverse proxy to redirect your Collabora office URL to it.
Additionally, you can “map” the quoted xml file to a local file and change the contents of the file to only read from your local IP’s.
docker run -t -d -p 127.0.0.1:9980:9980 -v /local/docker/filepath/coolwsd.xml:/etc/coolwsd/coolwsd.xml:rw -e “aliasgroup1=https://nextcloud.domain.online:443” --restart always collabora/code
You also should add to your environment -e a username and password to further harden your “admin” Collabora path.
