I tried to see if there were any posts regarding this and nothing came up in my search, but I’m very sorry if I missed one!
I started using Collabora to replace google sheets on android. And for the most part it works great, there’s a few annoyances but overall good. However, there’s one thing that I would desparately like to be fixed, or if it’s an issue with how I’m doing it help with setting things up better.
I use shortcuts to directly access a couple spreadsheets, and I use them multiple times a day. Initially there was no issue as after opening the files once in Collabora the app provides a shortcut option directly to the file in question.
The issue arises in that after opening the file a few times (or so it seems) the files are removed from the recent listed files and the shortcuts no longer function. Short term I can just reopen the file and the shortcut will work again; but is there away for Collabora to maintain a record of the file I opened in it?
Hi @erobin2003 welcome to the Collabora Online forum
Losing a shortcut you use several times a day is annoying, so thank you for the clear description.
Why it happens
The app does not store a copy of your files. It keeps a link to each file, and Android decides whether the app may still read through that link. Each time the start screen shows the recent files, the app checks every link, and it drops any file it can no longer read. The shortcuts point to the same links, so they stop working at the same moment. The recent list holds up to 30 files, so it is not running out of space.
Two more things play a part:
The menu you get by long-pressing the app icon only shows the three files you opened most recently. Opening a fourth file pushes the oldest one out of that menu.
When a file is opened from another app (a file manager, a cloud storage app, an email attachment), Android often gives our app access for that one session only. The link stops working later.
What to try
Open each spreadsheet from inside the app, with the Open button in the toolbar at the top of the start screen. When you pick a file this way, the app asks Android for permanent access to it.
Then long-press the app icon, and drag the entry for that file onto your home screen. This makes a home screen shortcut that does not change when you open other files.
If the spreadsheets are in a cloud storage app, try a copy on the phone’s own storage for a day or two. If the shortcuts keep working there, the cloud app is giving out a new link to the file after it syncs.
If it still happens, could you tell us:
the app version (from the About screen),
your Android version and phone model,
where the files are stored (phone storage, SD card, or which cloud app),
how you usually open them (inside the app, or from another app).
That will tell us whether it is a bug we need to fix in the app.
