Status monitoring
Hello, I would like to monitoring the service downtimes. As of now my monitoring service will try to connect to https://www.mycollaborawebsite.com/hosting/capabilities every 60 seconds.
Is there any better url I should try to ping to check the service status?
Thank you!
That’s a great file to fetch, very fast for the server to serve. Failing that - you could probably very easily add an ‘uptime’ metric to our Prometheus metrics - that might be useful for other people:
https://admin:admin@server.foo.com:9980/cool/getMetrics
Somewhere here would make sense:
if you’re up for a quick patch =)
Hello @mmeeks thanks for your reply. I would like to avoid any customization to the code nor I am using Prometeus.
As example, Matrix-Syanpse publish an /health page which returns a 200 - OK and doesn’t get logged by default.
It would be really nice to have something similar on CollaboraOnline.
So - please do file a github ‘feature’ / enhancement ticket for that - it should be an easy hack; very easy to add that - well within the scope of a new developer - it should be a couple of lines of code I think :slight_smile: a great, non-urgent task for a newbie.
Thanks.
