Good morning
following the update to version 22.05.10.2.1 of my Docker Kubernetes I find myself with all my menus in English while they used the version of the browser before, French for us.
Do you have an idea ?
Hi @Loubens and thanks for testing and reporting back.
Could you please paste here which integrator and version are you using? (e.g.: Nextcloud)
And which version of the connector (e.g.: which version of Richdocuments)
Pedro
THANKS
We are on our own integration iFrame with WOPI.
Our version is the COLLABORA/CODE:latest
I haven’t modified my coolwsd.xml since version 22.05.06.3.1
@pedro.silva
For information i tryed with Collaboda/code:22.05.9.3.1
I’ve the good language displayed, but when i upgrade to collabora/code:22.05.10.1.1, i’m in English only.
Tks
@pedro.silva
Anyone can help me ?
Tks
Hello @Loubens, apologies for the delay it seems this message got hidden in my inbox.
That’s odd as I think it should default to en unless there is some missing package or a config set. WRT to package:
For complete user interface localization you need to install Collabora Office language resources.
https://sdk.collaboraonline.com/docs/installation/Installation_from_packages.html#localization
This means you will need to install the respective packages for your language
They are not direct dependencies of coolwsd. For example for German dialogs on Debian/Ubuntu:
apt install collaboraoffice*de
in your case, possibly, en-GB or en-US.
Additionally, you can test a different language by passing an additional parameter lang into the url:
https://sdk.collaboraonline.com/docs/advanced_integration.html?highlight=lang#url-query-parameters
With this you can detect or even allow your users to switch their UI language within your integration and then simply pass it to the cool in the url
which is how other integrators have been doing
https://github.com/search?q=repo%3Aowncloud%2Frichdocuments%20lang%3D&type=code
The way you choose to implement this is up to you. Additional links:
Also please consider to update to a more recent CODE. 23.05 major release is already out for some time and the latest is the 24.04:
If you need individualized help and support please feel free to reach out via email sales@collaboraoffice.com
