Where to place the license code?
i have bought a license for collabora code. i use docker. Where do i place the license? In found nothing about it in the documentation.
Kind regards
hii @h.schramm
If you’ve purchased a license for Collabora Online and you’re deploying via Docker:
Where to place the license key?
The location and setup process for the license key are specific to your deployment, and not documented publicly in full detail for licensed versions.
According to the official Collabora SDK documentation:
“If you have purchased a license key, please contact your Collabora support team, who will help you set it up properly.”
:page_facing_up: Source: sdk.collaboraonline.com – Docker Installation
Next Steps:
  • Check your email from Collabora (or reseller) it usually includes support contact details.
  • Reach out to the Collabora support team directly.
  • Or : hello@collaboraoffice.com
Hii @h.schramm sorry i think i pasted the wrong email id here is correct one and i also updated on last thread as well
