I need some helkp on how to install collabora on my linux server
I checked all the documents around but there is no solution , i am stuck on the middle of the process
the last command that i did is:
sudo apt update && sudo apt install loolwsd code-brand
Hey @iris,
All the latest installation information can be found here:
If you need any more help, just ask. ![]()
