I wanted to integrate COOL in my product where my application server would be the WOPI host. I have setup my application server and the COOL server (native setup, no docker nor the like) in the same virtual private network (VPC).
My application server terminates SSL, so the COOL server is requested by HTTP (non-SSL). I have disabled SSL in /etc/coolwsd/coolwsd.xml.
When testing curl http://<ip-address>/hosting/discovery
… works as expected → good.
Now I’m testing a simple, fake WOPI request in Chrome like http://<COOL-IP>:9980/cool/loleaflet/dist/loleaflet.html?WOPISrc=http%3A%2F%2F<my-app-server-domain>%2Fwopi%2Ffiles%2F123&access_token=AAA
… which fails since the socket is closed right away and I see this in the logs
coolwsd.xml Host Regex: Ensure it precisely matches your WOPISrc domain, including any ports.
WOPI Host CheckFileInfo: Verify your app server correctly responds to CheckFileInfo from the COOL server (e.g., via curl).
Logs: Set coolwsd.xml logging to trace for detailed error messages.
I actually already have reviewed most of the info/links you provided.
However, there is one item where I haven’t found specific info for:
Would you have a coolxsd.xml sample snippet on how exactly I needed to edit coolwsd.xml to enable my WOPI host? I really have not found any samples on that aspect. Some info indicates it should go by RegEx, other info suggests it should be plain domain name. Some info suggests the hostname should be with scheme and/or port, other info suggest the exact opposite.
It would be great if you had specific info there. Thanks again
… as per trouble shooting guide and got back {"status": "NotHttpSuccess"} which is expected and indicates that the connection between COOL WOPI and my app server is good.
Still the socket is closed right away, the COOL server does not call my app server on my test WOPI request as per my original post.
The NotHttpSuccess means COOL reached your app, but your /wopi/files/... isn’t returning a valid 200 OK with proper JSON. Check your logs, validate CheckFileInfo, and make sure tokens are handled.
Also, search past WOPI error topics in the forum — you’ll definitely find similar issues and fixes. But first, get your hands dirty and dig into the forum . https://forum.collaboraonline.com/search?q=wopi
my very problem is that the COOL server is not requesting my application server at all - I’m debugging my application server and can see that there is no request being made by COOL at all to my application server
the curl test above however proves that my application server is accessible from the COOL server - again confirmed by debugging my application server. The actual return code "NotHttpSuccess" is irrelevant in that case since it only proves my point: the communication from COOL → my application server works in principle
In the COOL logs I see a POST request - I can’t tell what that is actually needed for, since the very first step of any WOPI communication - and my test case - would be a GET request.
Anyway, right after that POST request the socket is closed - and I don’t know why - and the client side gets an error 400. Most importantly: the WOPI request does not make it to my application server at all.
I already browsed the forum and available resources for days but still am stuck. So far, I was unable to find a comparable case.
I’m not using SSL but non-SSL (I have disabled SSL in /etc/coolwsd/coolwsd.xml)
I’m not building nor compiling COOL. I only control the sources of my own application server (= WOPI host)
nowhere in COOL logs I would see error messages related to WOPISrc. In fact the WOPISrc parameter is detected correctly in my request (please see logs in my original post)
I’m running logging level = trace for now
I’m not using any JWT
Your suggestion on <host>^http://your-wopi-server:8080$</host> is a bit confusing since ^ and $ suggest this should be a RegEx. However, if it should be a RegEx then other characters like / needed it be escaped. Could you please clarify?
Also, I checked the C++ code related to the strange POST request (wsd/ClientRequestDispatcher.cpp:1892): since I don’t see any further logs after the POST request and before the socket close I would think the logic falls through to the exception in the final else branch in line 2208.
So I wonder what could be wrong on my test request curl -i 'http://<COOL-server-IP>:9980/cool/loleaflet/dist/loleaflet.html?WOPISrc=http%3A%2F%2F<my-app-server-domain>%3A8080%2Fwopi%2Ffiles%2F123&access_token=AAA'
… and why there is no GET request to my application server triggered but a POST request which as it appears throws the COOL internal exception.
After much tinkering and analyzing the CODE source code I found that the path of my sample request /cool/loleaflet/dist/loleaflet.html was wrong but needed to be /browser/dist/cool.html to make COOL sending a CheckFileInfo request to my app server.
Unfortunately I nowhere in the docs/forum/etc. would have found that important piece of information. The step by step tutorial even holds an incorrect path. It certainly would help other users if the docs could be amended accordingly.
Thanks a lot for taking the time to dig into this and share your findings!
You’re right that the path needs to be /browser/dist/cool.html for Collabora Online to correctly send a CheckFileInfo request. Just to clarify, this is actually mentioned in the documentation — for example, in the section describing the construction of the URL using the discovery XML:
However, we completely understand how this might have been easy to overlook, especially if other parts of the guide weren’t clear or consistent enough.
Apologies for the confusion, and thanks again for pointing it out we’ll review and improve the docs to make this detail more prominent and easier to follow.
