'X-Frame-Options' (frame does not open) in MS Edge
Hi team,
I am running a SuSE Linux server with
  1. Apache 2.4.51 (not docker)
  2. Owncloud 10.8.0 (not docker)
  3. CODE 21.06.9 (rpm packages, not docker)
This is my apache conf for collabora
Reverse proxy for Collabora Online
<VirtualHost *:443>
ServerName collabora.myserver.dee
ErrorLog /var/log/apache2/collabora.myserver.de-error_log
TransferLog /var/log/apache2/collabora.myserver.de-access_log
CustomLog /var/log/apache2/collabora.myserver.de-ssl_request_log ssl_combined
AllowEncodedSlashes NoDecode
ProxyPreserveHost On
static html, js, images, etc. served from coolwsd
browser is the client part of Collabora Online
ProxyPass /browser htttp://127.0.0.1:9980/browser retry=0
ProxyPassReverse /browser htttp://127.0.0.1:9980/browser
WOPI discovery URL
ProxyPass /hosting/discovery htttp://127.0.0.1:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery htttp://127.0.0.1:9980/hosting/discovery
Capabilities
ProxyPass /hosting/capabilities htttp://127.0.0.1:9980/hosting/capabilities retry=0
ProxyPassReverse /hosting/capabilities htttp://127.0.0.1:9980/hosting/capabilities
Main websocket
ProxyPassMatch “/cool/(.*)/ws$” ws://127.0.0.1:9980/cool/$1/ws nocanon
Admin Console websocket
ProxyPass /cool/adminws ws://127.0.0.1:9980/cool/adminws
Download as, Fullscreen presentation and Image upload operations
ProxyPass /cool htttp://127.0.0.1:9980/cool
ProxyPassReverse /cool htttp://127.0.0.1:9980/cool
Compatibility with integrations that use the /lool/convert-to endpoint
ProxyPass /lool htttp://127.0.0.1:9980/cool
ProxyPassReverse /lool htttp://127.0.0.1:9980/cool
<Location /browser>
Header unset X-Frame-Options
Header set X-Frame-Options SAMEORIGIN
<Proxy *:9980>
The last two sections of the configuration file I added in order to get rid of this error in
Microsoft Edge Version 96.0.1054.43 running on Windows 10:
Error message in console:
JQMIGRATE: Migrate is installed, version 1.4.0
2js.js?v=9571a9ef1ba4a65332b7b5c6e070bd40:2340
Deprecation warning: tipsy is deprecated. Use tooltip instead.
jQuery.fn.tipsy @ js.js?v=9571a9ef1ba4a65332b7b5c6e070bd40:2340
chromewebdata/:1
Failed to load resource: the server responded with a status of 403 ()
chromewebdata/:1
Refused to display ‘https://collabora.myserver.de/’ in a frame because it set ‘X-Frame-Options’ to ‘deny’.
(Index):2762
crbug/1173575, non-JS module files deprecated.
(anonym) @ (Index):2762
Editing of documents is not possible, I receive this warning in the browser window:
collabora.myserver.dee hat eine Verbindung verweigert.”
which translates to collabora.myserver.dee rejected a connection.
The CODE virtual desktop is not shown, I cannot edit any document.
Some snippet from the CODE page source reads like this:
var rd_instanceId = ‘ocladtdxrgqr’;
var rd_version = ‘0’;
var rd_sessionId = ‘0’;
var rd_permissions = ‘27’;
var rd_title = ‘ODT Format.odt’;
var rd_fileId = ‘159118’;
var rd_access_token = ‘EF3vIhWxmwGC60lf8GwcvaG0OsArJapU’;
var rd_access_token_ttl = ‘1638749563000’;
var rd_urlsrc = ‘htttps://collabora.myserver.de/browser/15dc78e/cool.html?’;
var rd_path = ‘/ODT Format.odt’;
var rd_canonical_webroot = ‘’;
I thought to remedy the problem by adding
to my apache config file (see above)
But, this did not help.
I do not get errors/warning from apache logs.
I wonder where
“Refused to display ‘htttps://collabora.myserver.de/’ in a frame because it set ‘X-Frame-Options’ to ‘deny’.”
comes from? I checked all config files for apache, there is no such entry.
I regularly cleared the browser cache, to no avail.
Any help greatly appreciated.
P. S. I had to add some letters in URLs since I am limited to post only 2 valid URLs (restriction of posting here)
