Android annoyances: pan instead of select, frequent reloading, etc
I’m having a lot of trouble with the Android version of Collabora Calc (25.04.9.1 from Play Store). On my Samsung tablet (SM-T870, OneUI 5.1.1 / A13):
(For clarity: “tap” means using the touch screen, “click” means using an external touchpad.)
  • I can’t edit the document without a physical keyboard
  • I have to double tap/click a cell to edit it (can’t just tap/click it once)
  • Documents are often reloaded in Viewing Mode without saving changes when attaching/detaching an external keyboard, rotating the screen, or waiting a while with Collabora minimized.
  • Sometimes I get a message “Disconnected from server” and can’t edit it anyway.
  • Tap+drag / click+drag on a selected cell’s handle is sometimes mistaken for panning, so sometimes more cells are selected (as desired) and sometimes the view jumps one way while the selection jumps the other (so for example, while I started with B15 selected and dragged 2 cells down + 2 cells right, now instead of B15 - D17 being selected, B13 - D15 are.)
I don’t see any settings other than light/dark theme, username for comments, and Chrome debugging. Is there some way to fix any of these problems (most especially the last one)?
