I have a problem with bookmark insertion inside CODE. When I try to insert a bookmark around multiple sections partially, the bookmark won’t be wrapped correctly. Example:
I try to wrap the bookmark around a bullet point and a paragraph:
I have a problem with bookmark insertion inside CODE. When I try to insert a bookmark around multiple sections partially, the bookmark won’t be wrapped correctly. […]
Hmmm. I tried to reproduce this on my end and it worked fine in Online:
COOLWSD version:
23.05.0.1 (git hash: 012b00d6)
LOKit version:
Collabora Office 23.05.0.1 (git hash: bc5c5de)
Served by: Linux Mint 21.1 6371e19d
which was a test version from a few weeks ago.
I also tested the desktop version of Collabora Office 23.05.0.1, and it worked fine there too.
And how are you inserting this bookmark exactly, are you:
Highlighting the text.
A normal text line + a few list/bullet points.
Pressing “Insert” Tab > “Bookmark” button.
Typing in a “Bookmark Name” + Pressing “Insert” button.
And then you:
Save the document + reopen it.
Your multi-line bookmark now starts/ends in the wrong text area.
When trying to do this inside Libreoffice, it will be wrapped correctly with no problem. Could this bug be fixed? Is there any workaround to do this?
Well, if it works in LibreOffice, it should work the same way in Collabora Office too.
I was able to get work in mine, so maybe it’s a bug that was recently fixed between your version + the latest.
(There’s also been LOTS of bookmark upgrades/fixes going on in the recent versions.)
