There is a search field but no search / replace function
Hi, thanks for taking the time to report this issue and for providing the details.
Could you please open a bug report in our GitHub issue tracker as well? That will help the developers investigate it properly and track the progress.
Thanks!
Do I need to create a new account on github? How do I identify the collabora list on github?
I tried to use my collabora login but it rejected it
Yes, you’ll need to create a GitHub account if you don’t already have one. The GitHub issue tracker is separate from your Collabora account, so your Collabora login won’t work there.
Once you have a GitHub account, you can report the issue in the Collabora Online repository here:
If you run into any problems creating an account or submitting the issue, let us know and we’ll be happy to help.
There is a connect button on the Collabera online interface which takes you through to GitHub. Does that do anything else?
Should I report whatever I consider to be a bug straight into GitHub?
Yes ![]()
What does the connect button on the collabora interface do? It takes you through to the GitHub website, what else does it do?
@pdfd i am not sure which connect button you are refering here can you please share screenshot or anything ?
Oh, no need to connect it there—that’s fine. The main issue just needs to be filed on GitHub, so it’s not necessary to include this link on the forum.
