Can’t upgrade on fedora43
There are long lasting problem when you are releasing upgrades on fedora. Here on fedora 43 for example
And it is not the first time this year.
package collaboraoffice-desktop-25.04.8-20251118.noarch does not verify: no digest
Hi @tajupido Sorry for the problem here.
We have already identified this problem and filled the issue on GH CODE dnf/rpm packages fail to install in fedora 43 with error: does not verify: no digest · Issue #13441 · CollaboraOnline/online · GitHub
It’s not possible to rebuild the packages, but we try to release compatible packages from now on.
Thank you @darshan. As I said before I am new here so I thought that CODE was something else and since I did not find any thing with fedora keyword I was a bit afraid of being the only one.
I just need to wait for the following release then if I understood you correctly.
