CODE 6.4.10_Docker - Nextcloud (Not working)
Well, it’s more like a band-aid :smiley: But I’m happy you also confirm this is the case, now I’m more hopeful that the next image will have the fix included!
If someone can not change certs order, add extra_params to it --o:ssl.ca_file_path= set ca path to empty will disable ssl verification.
This can be a workaround until next image release.
6.4.10.6 is released! It’s working for me!
6.4.10-6 includes this fix:
I have the same bug (SNI Error). Since 6.4.10-6, no SNI error in haproxy log but file cannot be download by CODE server.
Logs CODE:
wsd-00007-00033 2021-07-29 10:05:48.977030 [ docbroker_001 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:682
wsd-00007-00033 2021-07-29 10:06:18.962903 [ docbroker_001 ] WRN  Socket #33 has timed out while requesting [GET <hidden>/index.php/apps/richdocuments/wopi/files/12757253_ocuki09hwg9i?access_token=tPz45FAHtkPF7CdS8V1fga4we21RRaaV&access_token_ttl=0] after 30026ms| net/HttpRequest.hpp:1296
wsd-00007-00033 2021-07-29 10:06:18.982353 [ docbroker_001 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:682
Logs HAProxy:
Jul 29 12:06:19 proxy haproxy[60762]: 172.30.57.214:34276 [29/Jul/2021:12:06:18.993] HTTPS_Frontend~ cloud_backend_ipvANY/web1 0/0/1/233/238 200 15040 - - ---- 39/6/0/0/0 0/0 "GET /index.php/apps/richdocuments/wopi/files/12757253_ocuki09hwg9i/contents?access_token=tPz45FAHtkPF7CdS8V1fga4we21RRaaV&access_token_ttl=0 HTTP/1.1"
I don’t understand why HAProxy say “HTTP 200” and CODE server get socket timeout. If any people have an idea, i take it.
Thank You
I have exactly the same problem:
I can’t figure out where this might be coming from.
Again an error now version 6.4.10-9 Also the built-in version for nextcloud is failing.
At least OnlyOffice is working.
I have exactly the same problem since 6.4.10. Also updating to 6.4.10-10 does not solve it. So I’m still stuck at 6.4.9 which is the last working version.
Interestingly I have one external NC instance (remote on a different server) which works. My two local instances do show the reported issue with 6.4.10, my HAProxy also says HTTP 200 but the socket times out. Fully crazy, when I call the download URL in a browser it’s working immediately.
I really hope this will be fixed one day.
