I’m trying to open /loleaflet/dist/admin/admin.html , and it doesn’t accept username/pass that were defined at CODE app configuration. CODE itself seems to work, but not admin. Tried to change password many times already.
bearon
October 14, 2021, 6:17pm
2
Do you have an Apache reverse proxy set up, and if so, which version? It might be a duplicate of these in that case:
I enabled the Admin console and open it at https://$MYSERVER/loleaflet/dist/admin/admin.html. I get the error message “Der Server wurde heruntergefahren, bitte laden Sie die Seite neu.” (“Server has been shut down; please reload the page.”).
In the browser console (Chromium, Debian Testing) I see:
WebSocket connection to 'wss://$MYSERVER/lool/adminws/' failed
I also tried incognito mode and Firefox.
I installed the CODE Debian packages, loolwsd has version 6.4.10-4. The Apache config is exa…
opened 12:37PM - 19 Jul 21 UTC
closed 12:51PM - 11 Oct 21 UTC
bug
The bug is described here:
https://forum.collaboraonline.com/t/websocket-connec… tion-to-admin-console-adminws-is-failing/475
Duplicate issue:
https://forum.collaboraonline.com/t/code-cannot-launch-admin-console-after-update/477
TL;DR:
- Error message: “Server has been shut down; please reload the page.”
- websocket connection failing
- log: `Admin::handleInitialRequest bad request| wsd/Admin.cpp:378`
- This if should be true but isn't:
`if (request.find("Upgrade") != request.end() && Util::iequal(request["Upgrade"], "websocket"))`
- This commit touched the line recently: https://github.com/CollaboraOnline/online/commit/54a10729f3b5ac5913a051a0b810214e30a5b83a
I think it’s not the same, as I get a basic authentication prompt, but it doesn’t accept the password I’ve configured at app settings…
eugenem
October 17, 2021, 12:48pm
4
ok, I’ve installed a fresh UCS and CODE, and now admin works. Maybe it was related to upgrades, as I’ve started from old versions before that…
