CODE Nextcloud - Secure View settings
Hy, i have installed nextcloud and use Builtin CODE Server. It works really nice, but i have a need, that in secureview i must have the option to print (with the Watermark)
How can archive this goal?
brgds
hi @funsurfer
Thanks a lot for using CODE and for your kind feedback. It makes us very happy to see the community appreciating it. :blush:
Secure View intentionally disables printing. There is currently no option to allow printing while Secure View is enabled, even with watermarking.
If you need printing with a watermark, you must disable Secure View and enable watermarking in Nextcloud Office settings instead.
So currently:
• Secure View enabled → printing disabled
• Secure View disabled → printing allowed (watermark works)
Hy. Thanks for your replay.
But in Nextcloud Office i can not set up watermarking for all users. Or i am missing a setting?
Do you have admin rights ?
Yes it is selfhosted Nextcloud and I have installed it. :wink:
I have found in by mayself. Change file in Nextcloud APP works temp.
If anyone want to do the same:
Secure View - Print or download only with watermark? Ā· Issue #5452 Ā· nextcloud/richdocuments
brgds
@funsurfer Thanks sharing the solution :slight_smile:
