Hello
I am using docker-compose to set up Collabora and NextCloud with nginxproxy/nginx-proxy:alpine. NextCloud works fine. Collabora seems to be running but I am not able to access it. I think it might have something to do with the proxy. When I go to my Collabora domain https://office.[domain].com/ I get “502 Bad Gateway” and “nginx/1.23.3”. Is it expected that I should be able to get some kind of webpage results?
Included some logs and my docker compose configuration below.
Thanks for your help.
Collabora logs through docker-compose after boot-up:
nextcloud-collabora-1 | wsd-00001-00001 2023-08-19 08:03:04.509109 -0700 [ coolwsd ] TRC Have 1 new children.| wsd/COOLWSD.cpp:5722
nextcloud-collabora-1 | wsd-00001-00031 2023-08-19 08:03:04.509112 -0700 [ prisoner_poll ] TRC Executing SocketDisposition of #17: Type::CONTINUE| net/Socket.cpp:684
nextcloud-collabora-1 | wsd-00001-00001 2023-08-19 08:03:04.509139 -0700 [ coolwsd ] INF WSD initialization complete: setting log-level to [warning] as configured.| wsd/COOLWSD.cpp:5738
nextcloud-collabora-1 | Ready to accept connections on port 9980.
Proxy logs through docker-compose when trying to connect to domain.
nextcloud-proxy-1 | nginx.1 | office.[domain].com 192.168.1.1 - - [19/Aug/2023:15:10:25 +0000] "GET / HTTP/1.1" 301 169 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/116.0" "-"
nextcloud-proxy-1 | nginx.1 | 2023/08/19 15:10:25 [warn] 92#92: no resolver defined to resolve r3.o.lencr.org while requesting certificate status, responder: r3.o.lencr.org, certificate: "/etc/nginx/certs/office.[domain].com.crt"
nextcloud-proxy-1 | nginx.1 | 2023/08/19 15:10:25 [error] 92#92: *34 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.1.1, server: office.[domain].com, request: "GET / HTTP/2.0", upstream: "http://172.27.0.3:443/", host: "office.[domain].com"
nextcloud-proxy-1 | nginx.1 | office.[domain].com 192.168.1.1 - - [19/Aug/2023:15:10:25 +0000] "GET / HTTP/2.0" 502 157 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/116.0" "172.27.0.3:443"
nextcloud-proxy-1 | nginx.1 | 2023/08/19 15:10:25 [error] 92#92: *34 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.1.1, server: office.[domain].com, request: "GET /favicon.ico HTTP/2.0", upstream: "http://172.27.0.3:443/favicon.ico", host: "office.[domain].com", referrer: "https://office.[domain].com/"
nextcloud-proxy-1 | nginx.1 | office.[domain].com 192.168.1.1 - - [19/Aug/2023:15:10:25 +0000] "GET /favicon.ico HTTP/2.0" 502 157 "https://office.[domain].com/" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/116.0" "172.27.0.3:443"
docker-compose.yml
version: '3'
db:
redis:
app:
image: nextcloud:apache
restart: always
- VIRTUAL_HOST=nextcloud.[domain].com
- LETSENCRYPT_HOST=nextcloud.[domain].com
- LETSENCRYPT_EMAIL=my@email.com
- MYSQL_HOST=db
- REDIS_HOST=redis
- NEXTCLOUD_TRUSTED_DOMAINS=nextcloud.[domain].com [domain].com
- NEXTCLOUD_DATA_DIR=/srv/nextcloud/data
- TRUSTED_PROXIES=nextcloud-proxy-1
- NEXTCLOUD_HOSTNAME=nextcloud.[domain].com
- OVERWRITEPROTOCOL=https
- OVERWRITEHOST=nextcloud.[domain].com
hostname: nextcloud.[domain].com
env_file:
depends_on:
- proxy-tier
- default
cron:
image: collabora/code:latest
cap_add:
- MKNOD
- aliasgroup1=https://nextcloud.[domain].com:443
- username=collaboranextcloud
- password=[...]
- VIRTUAL_HOST=office.[domain].com
# - VIRTUAL_PORT=443
- LETSENCRYPT_HOST=office.[domain].com
- 9980:9980
restart: always
- "/etc/localtime:/etc/localtime:ro"
- proxy-tier
- default
#https://sdk.collaboraonline.com/docs/installation/CODE_Docker_image.html
#FROM nginxproxy/nginx-proxy:alpine
#COPY uploadsize.conf /etc/nginx/conf.d/uploadsize.conf
proxy:
build: ./proxy
restart: always
- 80:80
- 443:443
labels:
com.github.jrcs.letsencrypt_nginx_proxy_companion.nginx_proxy: "true"
- certs:/etc/nginx/certs:ro
- vhost.d:/etc/nginx/vhost.d
- html:/usr/share/nginx/html
- /var/run/docker.sock:/tmp/docker.sock:ro
container_name: nextcloud-proxy-1
- proxy-tier
letsencrypt-companion:
image: nginxproxy/acme-companion
restart: always
- acme:/etc/acme.sh
- /var/run/docker.sock:/var/run/docker.sock:ro
- proxy-tier
depends_on:
- proxy
proxy-tier:
