Andtwo
1
I deployed Collabora using docker run -t -d -p 9980:9980 -e "extra_params=-o:tls.enable=false" -e "domain=172\.16\.26\.233" collabora/code
and i have already config Collabora plugin on pydio cells’s plugin website
when i open the xxx.doc file,the website become blankspace
Quick Checklist for Your Setup
1. Your Docker Run Command
docker run -t -d -p 9980:9980 \
-e "extra_params=-o:tls.enable=false" \
-e "domain=172\.16\.26\.233" \
collabora/code
That’s fine if you’re accessing Collabora via HTTP and on the same local network. However, Collabora CODE is strict about domain for security.
You must escape the entire hostname/domain, and sometimes even IPs can be finicky.
Fixes to Try
1. Use Correct Domain in domain=
Try matching exactly what Pydio sends as the host in the iframe WOPISrc.
Run like:
-e "extra_params=--o:ssl.enable=false" \
-e "domain=172\\.16\\.26\\.233" \
collabora/code
Note the double escape: 172\\.16\\.26\\.233 — Collabora expects regex.
2. Ensure WOPI Host Is Allowed
Add --o:ssl.termination=true and set the proper WOPI origin via env:
-e "aliasgroup1=http://172.16.26.233:9980"
You can add more alias groups if your Cells UI is served from another IP/hostname.
Pydio Plugin Settings
LibreOffice SSL: Leave unchecked if you’re not using HTTPS for Collabora.
Skip Certificate Verification:
Yes, since there’s no cert.
Libre Office Host: Make sure it points to:
Also Check
1. Browser Console
Open DevTools → Console & Network tab. Look for:
- 404 or 403 errors
- CORS errors
- iframe blocked or WOPI rejection
2. Collabora Logs
Check:
docker logs <container_id>
Look for:
- WOPI host not allowed
- Document load failures
- Errors with
.uno commands
3. Check Pydio Cells Version Compatibility
Not all versions of Cells fully support the Collabora plugin out of the box. Ensure you are on a recent version (4.x+).
Final Suggestion
Try loading the WOPI file directly in an iframe using the WOPISrc format:
http://172.16.26.233:9980/loleaflet/dist/loleaflet.html?WOPISrc=http://<pydio-cells-IP>:8080/your-wopi-endpoint
If that works, it confirms the Collabora server is fine and the issue is with the plugin config in Cells.
