Collabora with nextcloud and traefik on docker
hi there!
I installed Nextcloud (version 31.0.5), Collabora CODE (version 25.04.2.1) and Traefik (version >= 2) with Docker
Nextcloud is up, I set collabora url on page http s://cloud.domain.tld/settings/admin/richdocuments and now see the green block (“Collabora Online server is reachable.”) but on the same page, the iframe below displays an error and I can see a 400 bad request on http s://code.domain.tld/browser/dist/fetch-settings-file in the browser debugger
Ofc I can’t edit any document…
I see these errors in collabora logs:
[ websrv_poll ] ERR Failed to get settings json from [http://cloud.domain.tld/index.php/apps/richdocuments/wopi/settings?type=systemconfig&access_token=&fileId=-1] with status[Moved Permanently]| wsd/DocumentBroker.cpp:1835 <= I’m pretty sure it’s caused by the http to https redirection
[ websrv_poll ] ERR #-1: Failed to install config [shared-http_cloud.domain.tld/index.php/apps/richdocuments/wopi/settings-]| wsd/RequestVettingStation.cpp:209
what I already checked:
  • Nexcloud container can curl http s://code.domain.tld/hosting/discovery
  • CODE container doesn’t include curl, wget or ping so I hope it can reach nextcloud
  • I can log in on https ://code.domain.tld/browser/dist/admin/admin.html
I found this doc: CODE Docker image — SDK https://sdk.collaboraonline.com/ documentation and understand I should configure some options in /etc/coolwsd/coolwsd.xml but it’s not mounted (yet?) so it would be gone each time I rerun container (which will be pretty often until everything is fully configured :D)
I haven’t fixed this message yet: " You have not configured the allow-list for WOPI requests. Without this setting users may download restricted files via WOPI requests to the Nextcloud server."
do you think it’s a setting issue with Collabora CODE or something wrong with Traefik?
NB: had to “break” links on purpose as I’m a new user :slight_smile:
thanks in advance!
Hello @Elianora Welcome to collabora online forum
I have very similar question and there is a nice discussion on this topic. I would like if you can read those points and check if that helps ?
thanks!
I read that thread and changed a few traefik labels and it works now!
let’s fix every security stuff now :wink:
Awesome @Elianora
If it’s okay can you share how you solved it ? It’s better for other users :wink:
you’re right!
I changed a few labels in the 3 files so I’m not sure wich change fixed the issue but here’re my working docker-compose files:
Traefik:
  traefik:
    image: traefik
    container_name: traefik
    restart: always
    command:
      - "--api.insecure=true"
      - "--providers.docker=true"
      - "--providers.docker.exposedbydefault=false"
      - "--entrypoints.web.address=:80"
      - "--entrypoints.websecure.address=:443"
      - "--entrypoints.websecure.asDefault=true"
      - "--entrypoints.wss.address=:9980"
      - "--certificatesresolvers.letsencrypt.acme.httpchallenge=true"
      - "--certificatesresolvers.letsencrypt.acme.httpchallenge.entrypoint=web"
      - "--certificatesresolvers.letsencrypt.acme.email=contact@domain.tld"
      - "--certificatesresolvers.letsencrypt.acme.storage=/letsencrypt/acme.json"
      - "--accesslog=true"
      - "--accesslog.format=json"
      - "--accessLog.filters.statusCodes=400-499"
      - "80:80"
      - "8080:8080"
      - "443:443"
    expose:
      - 8080
      - "./traefik.yml:/traefik.yml:ro"
      - "./letsencrypt:/letsencrypt"
      - "/var/run/docker.sock:/var/run/docker.sock:ro"
      - nextcode
    labels:
      - "traefik.http.routers.traefik.middlewares=traefik-basic-auth,traefik-https-redirect,traefik-https-forward"
      - "traefik.enable=true"
      - "traefik.http.routers.traefik.rule=Host(`proxy.domain.tld`)"
      - "traefik.http.routers.traefik.entrypoints=web"
      - "traefik.http.routers.traefik.tls.certresolver=letsencrypt"
      - "traefik.http.routers.traefik.service=api@internal"
      - "traefik.http.middlewares.traefik-basic-auth.basicauth.users=admin:$$apr1$$aepdom5b$$Ojf8ES2LsBFHBN4DcON2P1"
      - "traefik.http.middlewares.traefik-https-redirect.redirectscheme.scheme=https"
      - "traefik.http.middlewares.traefik-https-forward.headers.customrequestheaders.X-Forwarded-Proto=https"
      - "traefik.wss.protocol=https"
      - "traefik.http.routers.traefik-secure.entrypoints=websecure"
      - "traefik.http.routers.traefik-secure.rule=Host(`proxy.domain.tld`)"
      - "traefik.http.routers.traefik-secure.middlewares=traefik-basic-auth"
      - "traefik.http.routers.traefik-secure.tls=true"
      - "traefik.http.routers.traefik-secure.service=api@internal"
  nextcode:
    external: true
nextcloud:
  db:
  redis:
  app:
    image: nextcloud
    restart: always
    depends_on:
      - redis
      - db
      - nextcloud:/var/www/html
      - TZ=Europe/Paris
      - MYSQL_PASSWORD=<db-password>
      - MYSQL_DATABASE=<db-name>
      - MYSQL_USER=<db-user>
      - MYSQL_HOST=db
      - NEXTCLOUD_TRUSTED_DOMAINS=nextcloud.domain.tld
      - VIRTUAL_HOST=nextcloud.domain.tld
      - OVERWRITEPROTOCOL=https
      - NC_default_phone_region=FR
    labels:
      - "traefik.http.routers.nextcloud.rule=Host(`nextcloud.domain.tld`)"
      - "traefik.http.routers.nextcloud.entrypoints=websecure"
      - "traefik.http.routers.nextcloud.tls.certresolver=letsencrypt"
      - "traefik.http.services.nextcloud.loadbalancer.server.port=80"
      - "traefik.http.routers.nextcloud.middlewares=nextcloud_redirectregex@docker"
      - "traefik.http.middlewares.nextcloud_redirectregex.redirectregex.permanent=true"
      # caldav and co
      - "traefik.http.middlewares.nextcloud_redirectregex.redirectregex.regex=https://(.*)/.well-known/(?:card|cal)dav"
      - "traefik.http.middlewares.nextcloud_redirectregex.redirectregex.replacement=https://$${1}/remote.php/dav"
      - "traefik.http.routers.nextcloud.middlewares=nextcloud_hsts"
      # hsts
      - "traefik.http.middlewares.nextcloud_hsts.headers.stsSeconds=15552000"
      - "traefik.http.middlewares.nextcloud_hsts.headers.stsIncludeSubdomains=true"
      - "traefik.http.middlewares.nextcloud_hsts.headers.stsPreload=true"
      - "traefik.http.middlewares.nextcloud_hsts.headers.forceSTSHeader=true"
      - 'traefik.http.middlewares.nextcloud_hsts.headers.customRequestHeaders.X-Forwarded-Proto=https'
      - nextcode
  nextcloud:
    driver: local
    driver_opts:
      device: /home/<my-user>/nextcloud/data
      o: bind
      type: local
  db:
    driver: local
    driver_opts:
      device: /home/<my-user>/nextcloud/db
      o: bind
      type: local
  nextcode:
    external: true
and collabora CODE:
    image: collabora/code:latest
    - "9980:9980"
      - domain=nextcloud.domain.tld
      - aliasgroup1=https://nextcloud.domain.tld
      - username=<admin-user>
      - password=<admin-password>
      - extra_params=--o:ssl.enable=false --o:ssl.termination=true --o:net.frame_ancestors=*
      - VIRTUAL_HOST=collabora.domain.tld
      - DONT_GEN_SSL_CERT=true
    labels:
      - 'traefik.enable=true'
      - 'traefik.http.routers.collabora.tls=true'
      - 'traefik.http.routers.collabora.tls.certresolver=letsencrypt'
      - 'traefik.http.routers.collabora.entrypoints=websecure'
      - 'traefik.http.routers.collabora.rule=Host(`collabora.domain.tld`)'
      - "traefik.http.routers.collabora.service=collabora"
      - "traefik.http.middlewares.collabora-headers.headers.customrequestheaders.Upgrade=websocket"
      - "traefik.http.middlewares.collabora-headers.headers.customrequestheaders.Connection=Upgrade"
      - 'traefik.http.routers.collabora.middlewares=collabora-headers'
      - 'traefik.http.services.collabora.loadbalancer.server.port=9980'
      # reverse proxy
      - "traefik.http.middlewares.collabora-headers.headers.customrequestheaders.X-Forwarded-Proto=https"
      - "traefik.http.middlewares.collabora-headers.headers.customrequestheaders.X-Forwarded-Host=collabora.domain.tld"
      - 'traefik.http.middlewares.collabora-headers.headers.referrerPolicy=no-referrer'
      - 'traefik.http.middlewares.collabora-headers.headers.stsSeconds=15552000'
      - 'traefik.http.middlewares.collabora-headers.headers.forceSTSHeader=true'
      - 'traefik.http.middlewares.collabora-headers.headers.stsPreload=true'
      - 'traefik.http.middlewares.collabora-headers.headers.stsIncludeSubdomains=true'
      - 'traefik.http.middlewares.collabora-headers.headers.browserXssFilter=true'
      - 'traefik.http.middlewares.collabora-headers.headers.customRequestHeaders.X-Forwarded-Proto=https'
    cap_add:
      - MKNOD
      - nextcode
    restart: unless-stopped
  nextcode:
    external: true
I’m not finished with all the security check so consider these as a working base only :stuck_out_tongue:
Great work @Elianora Keep it up :tada:
