Hello
We have a problem when saving documents from an iFrame, error 400 impossible to convert the file.
We are with a Kubernete and 5 pods behind.
When we have only one pod it works well, but since the load has increased we have this problem.
Someone to help us?
@lpranam Hello
We are testing with Kubernetes.
1 ingress and X pods depending on the load which are created automatically.
I have a wopisrc in my url.
When I have 2 - 3 or more pods created, I open my document and everything works, however if a second person tries to open it, sometimes they are not on the same pod and both people are not working on the same version. So when one saves, the other does not find its modifications and vice versa.
Also when I try to convert a .DOC to .PDF it happens that it works, and sometimes I get a 400 error.
Do you want me to share the conf of my ingress with you?
I manage to save or print my documents, but sometimes two people are not on the same pod.
I think the wopisrc should be tracked in ingress, but I don’t see how to add it.
But my cookie is configured with 2 arguments, the first changes and the second does not. 0e1a2df22555e7162d803b4470cc7e44|fe892daf2c71c7db8a54253a5e078490
I am sometimes on the same document, sometimes on a different one.
Do you have an idea ?
I turn around…
ideally, for nginx you don’t need cookies just the config which I pasted above is enough for routing correctly unless you are using cookies for something else.
Thank you, I just made the modification without COOKIE, and it seems to work correctly, I forced the creation of 4 pods and opened the same document with 6 people and they are all on the same document (so same pod), and I I opened another with 3 people and the same.
Again a big thank you.
On the other hand, is it possible to have information on the number of documents opened in full on all the pods?
Or way to know on which pod we are connected when we are in https://libreoffice.mydomain.combrowser/dist/admin/admin.html
Thanks in advance.
