COOL TC meeting minutes: 2026-04-15
Present:
  • Caolan, Michael M, Stephan, Andras, Darshan, Heiko, Leif,
    Michael S, Sahil, Szymon, Tomaz, Miklos
Action items
  • explore what is possible with gerrit for welcoming (Darshan)
Monorepo (Andras)
  • We have this on gerrit – you can check it out
  • Unification of core & online repos is done.
  • Working on getting CI setup currently.
  • Meanwhile we can continue merging in old repos until CI is setup
    • then we will need to merge patches across.
    • Hopefully not many to merge across
  • Use git format-patch and edit paths of the patch fragments and git am < it.
  • Don’t forget to git commit -s # to sign patches
  • Notable changes:
    • core → engine/ as a sub-folder
      • automake kindly rm -Rf’s core on make clean – so could not use it.
    • Added dictionaries/ directly
    • Leaving translations for later
    • Leaving helpcontent until later too.
  • Next steps:
    • CI working
    • make github readonly
    • moving patches across
    • then translations.
Releases (Andras)
  • doing releases from the stable branches as normal – no changes.
  • more interesting - plan to have a 26.04 Beta before COOL-days
  • like to release new Collabora Office from same 26.04 code-base
    • for Windows/Mac/Linux etc.
CI status (Szymon)
  • Was failing a lot last week (13%, Failed: 207/240)
  • Now most of the time passes on GH (with some unstable desktop cypress test)
  • Mohit and Caolan fixed most of the problems
    • multiple problems at the same time – impossible to fix both at the same time.
Gerrit performance (Andras)
  • Potentially being crawled by lots of spam / AI sucking devices …
  • **AI: **File a ticket here – and CC me (Andras)
Patch review (Darshan)
Bug reporting
  • **AI: **build some bug stats for next time (Darshan)
Removing Poppler (Michael S)
  • Up-loaded a patch to gerrit
  • fails now inside a VCL meta-file unit-test, with some PDF action.
  • In the sdext module – there is some type-detection
    • code that extracts embedded Hybrid-PDF bits – so we need to keep that.
TTT talks
COOL days
  • Now under two weeks out – please work on your slides
Gerrit permissions
  • Find it handy to have push permissions in gerrit (Caolan)
    • as in approved but with minor cleanups
    • is there a “push when approved” permission.
    • Not clear if it is possible (Andras)
  • If we want the github model (Miklos)
    • matching thing is to have submit rights for all recognized developers
    • if waiting for a mentor takes too much time – other people can do the review.
      • would require.
  • AI: add commit rights for everyone that has them on github (Andras)
What’s next
  • Michael S
    • fixed the first horror RTF problem of a set
  • Stephan
    • CODA-Q collaborative editing fun
  • Szymon
    • slides for COOL-days + more debugging tools for tiled rendering
    • testing comments needing improvement
    • working on DOCX property preservation
  • Quikee
    • PDF primitives / renderer found some issues while back-porting to 25.04
      • some changes there – fixing those
      • main not working yet either – changes there too
    • horrors with fonts
      • found a good solution here.
    • Vector rendering
      • worked on getting thumbnails in impress working
  • Darshan
    • Improved hyperlink and data validity cell tooltip styles
    • community website updates
    • slides for cool days
    • next:
      • bug on view-mode, D&D in view-mode changing the document
      • should not be allowed in view mode - different from readonly
  • Sahil
    • getting PR’s merged – eg. dynamic zoom for Impres
  • Michael M
    • typing text, not code sadly.
  • Miklos
  • Caolán
  • Leif
    • trying to get it building
    • getting some Sailfish stuff setup for COOL-days
