Present:
- Michael M, Noel, Andras, Caolan, Michael S, Stephan, Thorsten, Tomaz, Miklos
Completed action items
Pending action items
- For next week set stats tool to monitor monorepo (Szymon)
Monorepo setup (Michael M)
Long way down this path already …
No perfect solution of which way to merge here (Miklos)
- not re-writing history was a design feature.
git blame follows the renames nicely
git log –follow # is not working
a wrapper script that tries to make this nicer
https://lore.kernel.org/git/afmfSa-p-9vuDL3E@collabora.com/T/#u
re-using the same logic of git blame
cautiously optimistic that this can be accepted
should make life much easier.
Unhappy with core merged into online, not the other way around (Noel)
- most of the commits are on the core side
What is the primary concern? (Michael M)
web links are not a concern (Michael S)
all other places where commits are referenced is a problem
possible: when rewrite the history, add a footer with the old hash
More happy with adding a footer header to the old git commit hash, if we do a rewrite (Stephan)
Can’t mirror to standard web hostings without this (Thorsten)
Lot of problems with redoing the work of the past month (Andras)
Concerned that this takes time instead of focusing on more important things
The required work sounds quite large, for little benefit
Pros
Can structure the tree the way we like, git-log works trivially
Can mirror to github
Cons
Redoing the done work of creating the monorepo (Andras)
Getting commits by old hashes requires some workaround or other
Who would be interested in doing the work here? (Michael M)
interested in writing the tooling (Noel)
branches? (Michael M)
What is the problem with broken objects ?
Some of the E-mail addresses have an invalid format – author/committer wrongly formatted
- check for other things too [!] and test it.
‘git fsck’ can detect these (Stephan)
github issue → could we clone existing broken LibreOffice github core repo – and re-purpose it as our online repo ?
And add our online around it ?
Can we take the core repo – move it into the engine/ directory
and as a 2nd root take the online repo ? …
Do we run clang-format on the changes ? (Michael)
keep re-write as minimal as possible – excited, and do lots of things
improvements to the product. -
clang-format breaks operators … and comments etc (Stephan)
git blame 564ec47db30e8^ sc/inc/document.hxx (Noel)
- this runs in the top-level folder, but not inside engine/
real problems with configure.ac which is in engine/ and the core
Conclusion:
give this a bit more time – lets see if git log will work out of the box
re-visit in a while.
Monorepo status
Still to be added on main: --enable-coplugin, fuzzer, lighthouse
Branches: this remains unchanged for now, only GitHub has CI (Andras)
Then make github readonly, moving patches across, then translations.
Releases (Andras)
CODE 26.04:
Need to write the packaging jobs for COOL & CODE – so far only snapshot bits.
Translation integration into repository / build needs doing
- with weblate setup – checked in without line #’s
like to release new Collabora Office from same 26.04 code-base
- for Windows/Mac/Linux etc.
CI status (Szymon)
Had a big backlog
Two problems were causing test failures recently
- now fixed.
Time to build ~ 70 minutes
when splitting separately – desktop tests take ~40 minutes. (Andras)
previously we had four different Jenkins / CI jobs – so things ran in parallel
currently cypress does one after another – we should do them in parallel
We can do even more – we have 120 tests in desktop/
- we have 60 tests in mobile, and fewer for the others.
Can we do something different ? (Noel)
one cypress jenkins job – and run more of the tests in parallel
currently we only run four in parallel.
Chrome has to be started, interface is clicked etc.
Noel has a patch in progress to run sixteen in parallel.
will switch to this scheme as/when can stop github jobs
why wait ? (Noel)
can we do this now ?
Requires stopping the CI for github immediately ? (Andras)
- we have around 80 PRs there to test/merge before closing github down.
Many of these perhaps wait for gerrit to have good CI
Adria is moving checks from github → gerrit for co-25.04 branch → WIP.
Can remove 23.05 jobs soon – when this is EOL’d soon
- we can re-enable the job if necessary – it’s the git objects and build artifacts.
Flatpak builds really necessary for every patch? (Noel)
has a bottleneck of getting bits in the end-stages of the build assembled (Stephan)
this takes a while.
Instead of letting Jenkins build a flatpak which is different to flathub anyway
can build CODA-Qt as a non-flatpak as well, switch CI to do that – should be quicker without the flatpak overheads
flatpak is the limiting factor → even longer than cypress → ~80 minutes
pulling in the developer environments …
Need an LXC container it builds in …
If Alma-linux-11 has it – fine …
- need a recipe for an LXC container that can build coda-qt
enough to suggest a distro that has an LXC container & so on.
Goal is nice developer experience …
Don’t have a Windows compilation job currently …
- also planned → needs to be done – to have dependencies for CI windows machine
so far have deps on package builder machine.
Patch review
**All changes: https://gerrit.collaboraoffice.com/q/status:open±is:wip**
- Week 19: 203
**PRs to migrate from GitHub**
- Week 19: 82
Bug reporting
Regression issues: https://github.com/CollaboraOnline/online/issues?q=is%3Aissue%20state%3Aopen%20label%3Aregression
- Week 19: 19
TTT talks
What’s cooking
Michael S
- Poking at lots of release branches for security fixes
Stephan
JS UNO callback ideas going in …
Collaboration thing into some gerrit patches …
Andras
already published Snap package on the snap store …
everyone can install & try.
Missing – to write a CI job to produce the snapshots regularly
marketing + home-pages on Ubuntu snap-store needs doing.
- In theory can update at any time – need to move this to the monorepo …
Szymon
- Missing Szymon
Quikee
Getting missing JSON primitive processor merged – then how to get online bits in too
trying to get the rendering working again – not just for thumbnails but whole slides
even today changes are going in …
Miklos
https://github.com/CollaboraOnline/online/issues/15451 redline improvements
Check 26.04 Writer incremental layout performance
Caolán
crashtesting is up & running, many finds (~700), improving (~500)
merging a11y patches left and right too …
Thorsten
- customer branch maintenance
Noel
cypress_test parallelization work
trying to find memory leaks
Michael M
- faster spell-checking in calc cells… avoiding idle invalidation
