Date: 2026-05-13
Present:
- Heiko, Stephan, Szymon, Thorsten, Caolan, Miklos, Tomaz, Michael S, Hub, Andras
Completed action items
- For next week set stats tool to monitor monorepo (Szymon)
Pending action items
Cleanups (Michael M)
First:
removing big bits of Base
removing chunks of VCL
- platform-dependent parts for Windows & macOS (Thorsten)
canvas/ & slideshow/ modules
Then
re-working sal/ string classes to move helpers in from comphelper, dropping the map-files, versioning
the map files are gone already (Stephan)
could do the comphelper::string → OUString folding
clang re-writes from Noel for
com::sun:star-> co- a bit vague in its current form (Stephan)
Approved list of areas:
comphelper::string cleanup (Stephan)
- or Noel
canvas/ & slideshow/ removal (Thorsten)
Base: firebird sdbc removal? (Miklos)
- postgresql sdbc removal? report builder removal?
Java wiki publisher removal? (Michael S)
- doesn’t work with typical modern authentication (non-HTTP builtin) anyway
vcl: XML-based theming (Tomaz)
Monorepo status
Done: iOS, translations
Still to be added on main: Windows, Android; --enable-coplugin, fuzzer, lighthouse
Branches: this remains unchanged for now, only GitHub has CI
Mirror from gerrit to github
use Stephan’s script to have a mirror from github; name?
option: different name on github, then need no rename on gerrit
not a problem if the mirror repo has a a different name (Michael S)
just replace the old online.git README with a big fat warning
like this option, leaves online.git issues unchanged (Miklos)
option: rename online.git on github, affects github issue links
Then make github readonly
Releases (Andras)
CODE 26.04: try to release in 3 weeks, RCs every week
Need to write the packaging jobs for COOL & CODE – so far only snapshot bits.
Translation integration is done
like to release new Collabora Office from same 26.04 code-base
- for Windows/Mac/Linux etc.
Patch review
- Week 20: 186(+7)
- Week 20: 78(-4)
Bug reporting
- Week 20: 17(-1)
Jenkins / CI update (Szymon)
- Week 20: Success rate is 52%, failed builds are 24/50
Crash testing (Caolan)
2026-04-20 776 (-5, +703)
2026-05-05 547 (-471, +286)
- various fixed, build in progress
TTT talks
What’s cooking
Michael S
- Python 3.14 for the main branch; Windows still needs fixing
Stephan
- jsuno + CODA-q collaboration
Andras
- Calc tab colors are now working in COOL / CODA
Szymon
Test for missing tiles scenario: https://gerrit.collaboraoffice.com/c/online/+/2562
- documents current state, now we can add solution on top
Quikee
- working on the vector rendering + dynamic arrays for Calc / spill
Miklos
- https://github.com/CollaboraOnline/online/issues/15749 “Interdependent Change tracking fails with Formatting on top of formatting”
Caolán
Some efforts at fixing co-25.04 cypress
unifying & extending “update links”
coverity stuff
