Present:
- Stephan, Adria, Noel, Caolan, Leif, Andras, Michael M, Tomaz, Szymon, Miklos
Completed action items
Pending action items
File a github issue for the canvas / slideshow cleanup (Thorsten)
Look at on-demand HW from Hetzner (Andras)
File a github issue to track the com.sun.star → cpo name change (Noel). Done as rename com.sun.star → cpo · Issue #15927 · CollaboraOnline/online · GitHub
Monorepo status
CI~~– complete, only the fuzzer is under testing now, it broke this week
- was enable, then disabled – to try to get it into the best shape first
then github online.git: refer to gerrit
just have a README.md and nothing else in the main branch (?)
AI: remove ~everything (all code) there, except the README (Andras)
allows a workflow for pushing helm-chart pieces to various servers
The repo will continue to live, but only for the helm chart + docker + a few other bits.
**Releases **(Andras)
CODE 26.04.1 is out, released earlier this week
development can continue on main branch
distro/collabora/co-26.04 branch is created in case we have to release again for CODE 26.04.1 (and also for CODA)
Compact Websocket URL doesn’t work with old Apache reverse proxy configuration
added a remark to the release notes – but rather a difficult situation.
Sysadmins need to update their config (of the reverse proxy)
AI: add in fallback server URL support, and fall-back if the socket fails to connect to horror-style URLs – and note in red in the admin console (Caolan)
Junit tests (Noel)
Currently lokit distro config disables java, so all is well on CI
But JunitTest_svtools_unoapi started to fail, do we care?
Right now, they are bitrotting (Noel)
Multiple types here (Stephan)
mechanical checking of the UNO API, not really useful → can be removed.
- These use a template file / data-driven bits
not entirely sure how it worked, exclude lists etc.
more free-form “complex” tests, might be more useful; could be re-written in something else.
This morning ran fine for Stephan – as long as still there keeping them alive.
Could get rid of the “unoapi” ones, and leave the “complex” ones alone (Stephan)
Wasm CI (Stephan)
Would need a Wasm build (something like <https://cpci.cbg.collabora.co.uk:8080/job/gerrit_cowasm_main/>) plus a “plain” build with –with-wasm-fallback=…
For CI we have the WASM build – just that
We need for something we can run – a WASM build + a COOL build – with WASM fallback parameter – to bring that into the other build.
We would want to build the WASM blob separately (Michael M)
AI: Check some run-time configuration / logic as to whether we should serve the WASM or not (Stephan)
AI: generate a separate WASM package in due course with the necessary blob (Adria)
Patch review
- Week 24: 190(-6)
- Week 24: 26(-31)
- Week 24: Azerliap, Diego Nascimento, Mylo, Sleepy Sandy, ddi
- Week 24: Miklos Vajna (70), Caolán McNamara (37), Stephan Bergmann (34), Tomaž Vajngerl (33), Noel Grandin (32), Szymon Kłos (26), Mike Kaganski (21), Darshan-Upadhyay (6), Andras Timar (5), Gökay ŞATIR (5)
Bug reporting
- Week 24: 14(-3)
Jenkins / CI update (Andras)
Classical cypress problems are no longer that prominent
Had issues with the windows builds recently, Andras made lots of fixes of this today
- now it finishes on-time; all green now.
Hopefully this reduces the backlog by tomorrow
Had an issue with the fuzzer – but has been remove again
Had an issue with windows capacity (Adria)
interoperability workload halved the CI capacity there
spoke with Aron Budea – who can execute this manually; we’ll do it Saturday mid-day …
long term solution – Mitch & Aron are getting a VM setup – and run these on the VM not the CI host.
Takes a long time, doesn’t use much resources
- now updated the tool, it does work now (api call no longer returns 403)
Week 24: Success rate is 34%, failed builds are 33/50
Looks terrible but was 18% yesterday – trend is going up …
Worth re-basing to get past the cypress problems.
A recurring & not happy state (Stephan)
when your job fails – have to guess if someone else addressed the issue
Need a good way to communicate who is fixing CI …
- how to respond to builds being red without further overloading the setup.
Ask: people to announce when they are working on a known CI failure, and telling people when to re-base patches …
- suspect lots of this work is pointless re-basing.
Sometimes have a commit that does nothing (Miklos)
Google have a status page that says whether the tree is ‘open’ or not – ie. CI state is good
Not just us that has this problem.
Could go at the top of the gerrit page – work to keep it up-to-date.
But it is work to keep that up to date
Think we need more CI power (Noel)
don’t think we have enough to absorb the mishaps …
where are we at on shared ccache etc. ? (Michael)
task pending for flatpak builds & ccache – should improve (Adria)
- the bottleneck seems to be Windows capacity
Looking at the nodes – the windows node (Caolan)
waiting to configure that – perhaps double the throughput.
had an attempt to configure ccache on Windows (Andras)
modern Ccache can do that
or have a VM on the other physical windows box – which is idle most of the time ?
last week: windows was not a bottleneck – takes ~20mins
problem was changing the compiler configuration …
some used old, some used new
had to re-build everything; and mixed objects – couldn’t link – a big queue built up.
What’s next for releng
flatpak nightlies (Adria)
cypress lighthouse added to main checks. fuzzer is flaky, under review, trying to fix, plan to add new builder to not cause another bottleneck
fuzzer CI job
cleaning up remaining github jobs – to get more disk available.
Snap VM bits to be built in jenkins.
Created Collabora Office Preview on the Windows store → pending certification (Andras)
- later to up-load builds from Jenkins automatically
Re-visit new hardware next week.
Crash testing (Caolan)
2026-06-10 192 (-34, +0)
MatrixResizeGuard for ScColumn::CalcAll fix in motion
unshare formula cells the matrix import overwrites
2026-05-31 278 (-269, +0)
- crashtesting: defer dynamic-array resize while measuring optimal
row height fixed, hoping to hit the bulk of those now
TTT talks
What’s cooking
Regina
Stephan
- working on COOL extension documentation
Andras
- poco is built like other 3rd party libs (engine)
Quikee
Vector rendering goodness …
When we save svg files – into ODF – we always create this PNG fallback
- removed this – it’s been long enough to support that.
Think about natively supporting WEBP files – to avoid very slow deflate.
- AI: check LibreOffice loads WEBP files and switch to not doing the PNG conversion (Quikee)
Szymon
recovered CI monitoring
reproducing bugs currently: scrolling / navigator search
looked at comments layouting, TODO later (https://gerrit.collaboraoffice.com/c/online/+/3651)
Noel
css → cpo namespace renaming, nurse-maiding various other small cleanups through CI
script that does the bulk of the work – 1.5 million line diff: fun.
Perhaps could fixup commits we re-base across that.
Can this be done incrementally with writer indexing ? (Miklos)
could we do this step by step ?
eg. having a new namespace alias – cpo – resolves to com :: sun :: star – change meaning of cpo later ?
Move udkapi / offapi bits around …
Can we do the 1st step with namespaces incrementally ?
Miklos
- https://github.com/CollaboraOnline/online/issues/15921 “Writer HTML paste: lost background color”, improves paste from dark-mode Jitsi
Caolán
enabled that even-more-parallel cypress by default
a11y coverage complete
finalizing link control, was finished, some crashtesting, etc. finds though
bg save thread issue with writer grammar checker
Adria
flatpak nightlies repo
fuzzer job for monorepo main → improve shape
activated dco “signed-off-by” mandatory in commits
