Date: 2026-06-17
Present:
- Stephan, Adria, Caolan, Michael M, Michael S, Noel, Miklos
Completed action items
File a github issue to track the com.sun.star → cpo name change (Noel).
Add in fallback server URL support, and fall-back if the socket fails to connect to horror-style URLs – and note in red in the admin console (Caolan)
done, the last change is just pending CI
github online.git: remove all code there, the README etc stays (Andras)
wasm: Check some run-time configuration / logic as to whether we should serve the WASM or not (Stephan)
- pending <https://gerrit.collaboraoffice.com/c/online/+/4712> “Don’t tie MaxFileSizeToCacheInBytes to –with-wasm-fallback”
Check LibreOffice loads WEBP files (Michael)
- This works fine
Pending action items
File a github issue for the canvas / slideshow cleanup (Thorsten)
Look at on-demand HW from Hetzner (Andras)
- Lets re-visit after the CI section …
wasm: generate a separate WASM package in due course with the necessary blob (Adria)
- now unblocked by Stephan
switch code to not doing the PNG conversion for WEBP (Quikee)
Monorepo status
**Releases **(Andras)
CODE 26.04.1 is out, released last week
development can continue on main branch
distro/collabora/co-26.04 branch is created in case we have to release again for CODE 26.04.1 (and also for CODA)
Patch review
- 1Week 25: 199(+9)
- Week 25: 23(-3)
- Week 25: Ibnu Batuthah, Isaki23, Артур
- Week 25: Miklos Vajna (71), Caolán McNamara (46), Noel Grandin (32), Tomaž Vajngerl (26), Stephan Bergmann (21), Szymon Kłos (16), Michael Stahl (9), Andras Timar (7), Mike Kaganski (6), Michael Meeks (5)
Bug reporting
- Week 25: 12(-2)
Jenkins / CI update (Andras)
- Week 25: Success rate is 50%, failed builds are 25/50
Current state: pretty stable (Andras)
- 2 breakages yesterday (one unstable test, then wasm)
New hardware:
right now, it looks stable (Adria)
slower than ideal during peak hours; almost idle over the weekend (Andras)
Turnaround time? (Miklos)
good to have the median not avg …
getting the last ~100 builds …
AI: extract and log the build times – and present them next & every time (Adria)
E.g. what is the median turnaround time for “Gerrit for online main” in the last 50 builds
online.git scripts/cool_tc_stats.py ← extend this (Miklos)
There is ccache on windows machines which is great (Caolan)
Compiling without optimization might go quicker on Windows
gcc omits various warnings if not optimizing, not clear if windows does.
What is the slowest job? (Michael M)
Windows is stabilizing, but flatpak is the slowest one …
Depends – if something changes something fundamental in engine/ makes a big difference.
Competing patches – both pass CI, but when both merged everything fails (Andras)
- a huge queue piles up immediately when things go wrong.
Brings back the previous idea – for releng to bump build-fixing patches to the top of the queue (Caolan)
if confident – just merge it without waiting for CI and let people know
yesterday – Andras stopped 40 Jenkins jobs that would fail anyway; but we’d have to wait a day to see them fail.
We could instead abort as soon as a single platform fails ? (Miklos)
great if it’s a compiler error (Caolan)
bad if it’s Windows has run-out-of-space …
how to decide which is which.
**Caolan says: https://plugins.jenkins.io/PrioritySorter/ **
We could have bad commit ranges (Noel)
- just abort all builds in those ranges
AI: install PrioritySorter (Adria/Timar) → and re-start at the weekend.
Crash testing (Caolan)
2026-06-17 192 (-34, +0)
MatrixResizeGuard for ScColumn::CalcAll fix in motion
unshare formula cells the matrix import overwrites
Expect the run after next to be even better
Waiting for Aron’s feedback on the SmartDoc consensus
- lets dump them all in.
Can we write a batch fetching script for PPTX/PPT bits ? (Michael)
TTT talks
What’s cooking
Stephan
Noel’s OUstring work, completing that
CODA collaboration, getting that past review
Extensions/scripting, deploy story
Quikee
- vector rendering
Noel
looking at the cpo namespace rename (C++)
looking at doing this incrementally
Miklos
- https://github.com/CollaboraOnline/online/issues/15941 “Interdependent redlines: highlight on insert is broken”
Caolán
Related: cool#15918 use the compact WebSocket URL by default (for review)
ccache-shared: record relative debug paths and ship a gdb “cd” hook (merged)
perf: stop repeating the same status indicator percentage, stuck in ‘adapt row height’ (merged)
Adrià
CODA flatpak snapshot repo and setup to daily generation. Debug flaky(?) job
Debug why flatpak job is flaky in fermat (not in mersenne)
could allow add more flatpak build capacity
Cleanup github 24 & 26 jobs and ws from jenkins (migrate github 24 jobs to gerrit)
