COOL TC meeting minutes: 2026-07-01
Date: 2026-07-01
Present:
  • Caolan, Andras, Szymon, Mike, Noel, Thorsten
Completed action items
  • Lets use other Windows physical hardware – with a VM on it (Adria)
    • Mitch is on it as a sysadmin task
  • try the “disable optimization” idea (Caolan)
    • there was *more* warnings, so that is taken care of, not worse, maybe a little better
  • Already generated a cowasm package, to test here: https://www.collaboraoffice.com/downloads/COOL-Wasm-Nightly/ (Adria)
Pending action items
  • wasm: generate a separate WASM package in due course with the necessary blob (Adria)
    • job created, needs to be published somewhere to be useful
  • Jenkins: Install PrioritySorter and re-start at the weekend (Adria/Timar)
    • need to plan this
Agenda Items
  • Removal of Classic-related code e.g. https://gerrit.collaboraoffice.com/c/online/+/3873 “cool#15913 Remove internal/native slideshow from sd” (Noel)
    • IIUC this is the first commit that really drops the major functionality from the Classic part of the suite; this is normal, follows the direction – just IMO we need to disable Classic as a build option completely. (Mike)
    • There is a largest change by now that removes large parts of sd code, which makes impress basically unusable in classic (Mike)
    • Not really – that chance will result in an impress with no slideshow, and none of that code runs in online or CODA. Would like to keep desktop as testcase infra without crashing or slideshow and keep that working! (Thorsten)
    • The spell checking dialog edit area was also made effectively non-classic already (Caolán)
    • Slideshow removal alone: not enough to kill classic desktop in the monorepo. Removing the rest though is orthogonal to that idea. (Thorsten)
    • The direction of travel looks to me to make the distro lokit flags the default without using any explicit use, (Caolan)
  • Releases (Andras)
    • development can continue on main branch
      • co-26.04 branch will then receive a fast-fwd to main
      • no expectation of a need to explicitly port to 26.04 until then
    • CODA released – distro/collabora/co-26.04 / coda-26.04.1.4-1 tag
    • red CODE 26.04.2.1 released
Patch review
  • All changes
    • Week 27: 188(-4)
  • PRs to migrate from GitHub
    • Includes WIP and Draft pull requests, AI to owners to close those
    • Week 27: 10(+0)
    • Week 27: Ben Urban, Charles Chase, Filippo Moscatelli, Hans Henrik Juhl, hyperflint, muysup
    • Week 27: Caolán McNamara (63), Mike Kaganski (36), Tomaž Vajngerl (27), Noel Grandin (26), Stephan Bergmann (20), Szymon Kłos (16), Michael Stahl (15), Andras Timar (11), Balázs Varga (7), Darshan-Upadhyay (5)
Bug reporting
Jenkins / CI update (Andras)
  • Szymon’s monitoring: “last builds” monitoring
  • Gerrit for online main
    • Week 27: Success rate is 38%, failed builds are 31/50
    • Week 27: Turnaround time is 54 min (median of last 42 SUCCESS/FAILURE builds)
      • last-week was 2 hr 6 min avg and 6 hr 29 min last Wed
    • builds are more distributed during the day, and the queue peaks were less
      • build and queue metrics:
        • worst cases: windows 2:30h in queue, flatpak build 1:30h . This week much better since the commits are not entering the checks in “peaks” but more distributed during the day
      • felt better this week (Mike)
      • hard to tell if the root cause was fixed, or just because miklos and stephan were away (Noel)
Crash testing (Caolan)
  • 2026-07-01: 59 (-12, +1)
  • 2026-06-24: 70 (-122, +0)
TTT talks
What’s cooking
  • Stephan
    • vacation
  • Quikee
    • absent
  • Noel
    • conversions and removals and getting rid of old code, deprecated offapi/udkapi and perf work on invisible calc columns
  • Miklos
    • vacation
  • Caolán
    • CODA presentation efforts, better full-screen switching for QT and mac.
    • Experimenting with perf issues with webkits on desktop
    • Some experiments with busybox to see if it makes windows build any different
  • Adrià
    • **converted “privileged” containers in fermat and mersenne to “unprivileged”, and mitigated the risk in prime and bee, reducing possible attack surface
    • **checking flatpak debug artifact generation, to be able to debug locally
    • **finishing cowasm nightly process generation
    • CODE 26.04.2.1 release process
  • Szymon
    • cleaned various errors spotted in the logs (cypress and local kit console output)
    • working on DOCX styles handling (missing properties to sort and filter in the UI)
      • **followup for previous work **
  • Andras
    • l10n simplifications (generate translations from engine build-time)
    • CODA fixes and release work
    • Base our COOL/CODE docker on ZeNDiS hardened images
  • Michael M
  • Michael S
