Date: 2026-09-02
Present:
- Andras, Stephan, Mike, Szymon, Adria, Caolan, Tomaz, Michael M, Miklos
Completed action items
Pending action items
check that no builds are incremental anymore (Adria)
- the important ones (Windows) are fixed, still need to check
clang loplugin in code outside engine/, look at this (Adria)
- so build not only engine/ code in this config
Releases
- CODE 26.04: 26.04.4.1 next week
Patch review (Miklos)
- Week 36: 215(+15)
- Week 36: 2(+0) (macOS: Kendy)
- Week 36: Zewang0217
- Week 36: Miklos Vajna (124), Caolán McNamara (80), Stephan Bergmann (60), Andras Timar (44), Noel Grandin (43), Szymon Kłos (35), Mike Kaganski (21), Karthik Godha (16), Balázs Varga (16), Tomaž Vajngerl (11)
Bug reporting
- Week 36: 6(-1)
Jenkins / CI update (Adria)
last week drop of success 43% → 17% due to c++ and git fetch errors on CI
All the new builders are pre-warmed by now (Adria)
Week 36: Success rate is 50%, failed builds are 25/50
Week 36: Turnaround time is 48 min (median of last 46 SUCCESS/FAILURE builds)
- Yesterday was pretty good (Adria)
Getting the slow Intel Mac builder off ? (Michael M)
Due to work on new Mac hardware setup tomorrow (Adria)
- Mac Intel is off already.
Crash testing (Caolan)
2026-08-31: 86 (-1, +21)
- jump is mostly known, fix merged
2026-08-26: 66 (-12, +2)
TTT talks
Have a plan for the next two weeks
Multi-process modeling (Michael M)
Simulating processess …
- Would help with the macOS rules where you can’t fork inside the sandbox
Can we find and group our global state together
Don’t have a mechanism to make sure global state is protected (Miklos)
could have accessor pattern – can’t access without first locking it.
Might be able to do this without too much effort ?
Not a fan of lots of mutexes (Michael)
Global state → shared thread-local … (Quikee)
not screaming and running around – formular-bars – in a global state …
- made it thread-local – could help multiple formula-bars at the same time – was working.
Mildly amused (Caolan)
tried to put all these things into local functions – to get auto C++ thread-safe mutex
need to re-think all of that perhaps
no real feeling one way or the other.
Benefit for anything non-Mac-OS (Stephan)
can’t do fork for background save – like multiple-processes …
May be useful for Android + iOS (Michael)
Safer to spawn a process (Stephan)
only useful for CODA (Michael)
- Don’t use this stuff FakeSocket … could spawn on Windows / Linux but don’t.
Any crash brings all ‘processes’ down (Michael)
- seems scary but … auto-save in CODA etc.
What’s cooking
Miklos
- https://github.com/CollaboraOnline/online/issues/16131 SVG image paste from Chrome (URL)
Szymon
JSDialog fixes for reloading toolbars
Working on Impress
Adrià
**Added more CI capacity. **
+10 new linux agents for linux related jobs (cypress, android, dbgutil, etc.)
Working on enabling windows agent on incus VM to increase capacity. Goal -> to scale easy
Start working on enabling 2 new macmini M4 to increase macos / ios CI capacity
**retired Mac based on intel **
Monitoring enhancement - working on new grafana dashboard for CI (jenkins api + prometheus) to help identifying issues and taking remediation actions
Stephan
- GAS-like (Writer) JS extensions API
Caolan
An --enable-qt app build which coexists with server online, so one build for both outputs
An effort to have the “make clean” work done in parallel with make
I think it might be plausible to make msbuild do some more parallel building if some of the externals are shown to be a bottleneck
Andras
SBOM / supply chain
Docker: image-level SBOMs generated at build time; images published the way ZenDiS publishes its hardened bases
VEX: triaged all remaining SBOM scan findings (raptor 2.0.16 CVEs as fixed / not affected, two open items closed)
** Dependency bumps: OpenSSL 3.5.8, Python 3.14.7 (off the 3.14.5rc1 pre-release), d3 7.9.0 (d3-color ReDoS fix), dompurify 3.4.14**
Engine dead code and UI removal
**Desktop notebookbar fully removed: implementation, UI variant data files, UI mode chooser, User Interface dialog, addon
merging, SID_NOTEBOOKBAR, vcl leftovers, unread toolbar mode properties, stale log area
** Tools - Customize dialog removed (made unreachable, then dialog, slot ids and strings)
** Help - Send Feedback removed
** org.openoffice.Office.ExtensionManager configuration removed
** Old .NET Framework (CLI) UNO bindings and dead /clr gbuild support removed; CODA-W no longer builds the .NET UNO bridge**
CODA-W build without WSL, we can use MSYS2. WSL still works but MSYS2 is “advertised” in documentation
Localization: AI chat sends stable message codes so the client can localize them
Accept CIDR networks in every host allowlist – former regex syntax will work as well.
Tomaz
Vector rendering: master pages, note pages
- More primitives: glow effect
Mike
- Preparing for work on re-introducing multi-line links in PDF/UA, dropped earlier because of perf issues. Not started yet.
