Date: 2026-09-16
Present:
- Andras, Adria, Caolan, Regina, Stephan, Thorsten, Miklos, Szymon, Michael S, Michael M, Tomaz
Completed action items
Pending action items
check that no builds are incremental anymore (Adria)
still pending, first needs more capacity
also watch out for the hidden incremental Windows app problem, as discussed on Matrix
clang loplugin in code outside engine/, look at this (Adria)
- so build not only engine/ code in this config
Releases
CODE 26.04: 26.04.4.1 was tagged earlier this week
had build issues (build from tarball), fixed
the installation set had files with wrong permissions, fixed
testing, then to release, looks promising
will add a check to build from tarball to the CI (Adria)
CODE 26.04.4.2 “green” next week
- first will reset online.git co-26.04 to main
Patch review (Miklos)
- Week 38: 224(-27)
- Week 38: 2(-1)
- Week 38: Jonathan Carvalho, TDSxJONEY, WatsonTree
- Week 38: Miklos Vajna (126), Caolán McNamara (124), Noel Grandin (110), Szymon Kłos (97), Tomaž Vajngerl (62), Samuel Mehrbrodt (20), Stephan Bergmann (12), Mike Kaganski (12), Tor Lillqvist (8), Balázs Varga (7)
Bug reporting
- Week 37: 8(+2)
Jenkins / CI update (Adria)
New Windows build capacity
is the current bottleneck
Try to have the builder as an incus VM, to make maintenance easier
Also worked on mac mini setups to increase macOS and iOS build capacity
- growing clean successful builds again: 12% → 24% (looks good now)
Week 38: Success rate is 60%, failed builds are 20/50
Week 38: Turnaround time is 2 hr 42 min (median of last 43 SUCCESS/FAILURE builds)
Crash testing (Caolan)
2026-09-16: 11 (-11, +0)
- further improvement, fix for some more available.
2026-09-05: 21 (-69, +4)
- best numbers yet, new run underway might reduce further
Larger corpus: will instead switch to A / B runs of partitioned conversion bits …
already on a big machine
could we get the Jenkins hardware doing this at the weekend ?
- Not convinced that Jenkins is entirely idle at the weekend – it just drains the queue.
TTT talks
Have talks for the next two weeks
What’s cooking
Regina
- no updates
Szymon
fix: PostMessage API Get_Export_Formats
fix: missing styles after extension reload
working on Impress now
Stephan
GAS interop fidelity improvements (even better overload support; nullablity modeled with css.beans.Optional under the hood, …)
extensions in CODA
Caolan
combined coda+online build seems to be working, some more shrinking of re-compiles etc
- works in practice, usable; more work to be done
work to drop extra unused bg tab webviews in coda, hard bit merged, followups in progress, and then enable by default
- an LRU decision currently
Andras
dictionaries: extensions → normal files (we had nasty problems with extension registration in CODA)
engine’s extension framework becomes unused. Remove?
We have a replacement overall (Stephan)
reportedly there are customers using python extensions on the server side – which might be killed by this
Python scripts are inside the python scripted framework (Miklos)
- don’t think they are supplied as OXT extensions
just .py files in a folder as a sysadmin.
Off the top of the head – beyond dictionaries …
sounds good to get rid of it …
LibreLogo was ported to the new extension framework Stephan created
AI: drop the old extensions framework (Andras)
will do that as part of porting lightproof / sentence checker to C++ (Andras)
starting with 4 languages
Grammalecte would be the next target for French perhaps (Michael)
Adrià
- Windows Incus VM preparation to add Windows capacity for CI
Tomaz
Build the pivot table from cache
- can change layout even when source data is not available
Vector rendering
gradient and hatch rendering
optimize dx array (send differences from previous – 20% smaller)
master view / page view rendering
Miklos
- https://github.com/CollaboraOnline/online/issues/16206 “Writer collaborative editing: own cursor is not updated on adding a new bullet point”, then more copy&paste work
Michael M
Build performance … 10-15% speedup of calc compilation …
Grouping files … is that a good addition to PCH ?
Combining many files through includes into data.cxx from eg. sc/source/core/data/*
Chromium people tried this called it ‘Jumbo’ (Miklos)
**https://groups.google.com/a/chromium.org/g/chromium-dev/c/DP9TQszzQLI **
- they thought it was a failed experiment …
the pipmpls / forward declared headers are great (Caolan)
a 5% win is a huge plus for incremental builds for a developer.
PCH did help on the windows builds
CI – would re-build the externals / 3rd party lbraries from scratch (Caolan)
lots of individual configure scripts slow on Windows
- can use dash instead of bash …
might help – have a configure-value cache we can share on Windows
that is stored.
Stored like ccache is – keyed on the environment/configure options
Previously we built core only occasionally …
- Can we do something that cleans only internal modules ?
Could we have packaged software pre-installed as pre-conditions (Thorsten)
- cf. Linux – packages installed etc.
Can we do a “make internal-clean” instead ? (Michael)
we already have a ‘make internal.clean’ in engine/ (from Noel) (Miklos)
a “make stage clean” – so the next make will delete it in parallel – took a few seconds.
Decision: look at switching to semi-incremental on Windows – with a “make internal.clean” in engine and ‘make clean’ at top-level to try that (Adria)
would need to move every module except the ones in external/ for the background deletion optimization.
Report back after timing.
Cypress a complete disaster to parallelise (Caolan)
- everything dwarfed by the time it takes Cypress to run
CI throughput is unintuitive (Thorsten)
tests, setup, cleaning dwarfs compile times.
PCH on the full level for Linux seems good.
Inventing clever things that are run in CI but not developer builds (Stephan)
in the end this creates grief for everyone – CI builds randomly fail etc.
KISS is a good idea – if we can get enough hardware
CI Hardware is not yet fully loaded (Thorsten)
- not getting the full bang for the buck just yet.
Michael S
- SBOM generator for engine
