COOL TC meeting minutes: 2026-11-25
Date: 2026-11-25
Present:
  • Adria, Andras, Caolan, Michael S, Regina, Stephan, Thorsten, Michael M, Miklos
Completed action items
  • Master documents, review the design – see how much interaction from ‘master’ → child document and if we can do this via IPC / a WebSocket (Miklos)
  • Crashtesting: have a look into accelerating getting this setup (Adria)
    • the infra part is done
Pending action items
  • Write up the vector work and encourage people to test it in snapshots (Tomaz / Kohei)
  • Ask Meven to look at avoiding image decompression / memory allocation wherever possible in vector stream (Tomaz)
  • Releases
    • COOL 26.05.6.3 next week
    • CODA 26.04.6.4 in 2 weeks
Patch review (Miklos)
  • All changes
    • Week 48: 272(-53)
  • GitHub PRs
    • Week 48: 2(+0)
    • Week 48: Reefsoft, پرویز قادر
    • Week 48: Miklos Vajna (132), Tomaž Vajngerl (122), Noel Grandin (114), Caolán McNamara (113), Stephan Bergmann (74), Michael Stahl (44), Mike Kaganski (38), Sahil Gautam (24), Szymon Kłos (8), Pedro Silva (7)
Bug reporting
Jenkins / CI update (Adria)
  • Mohit’s monorepo test change → red
  • Cypress: 64% of 947 builds without a failed test over 7 days (Szymon’s stat)
  • Gerrit for online main
    • Week 48: Success rate is 47%, failed builds are 687/1288 (in the last 7 days)
    • Week 48: Turnaround time is 51 min (median of 1148 SUCCESS/FAILURE builds in the last 7 days)
    • Week 48: 72% of lone pushes got a CI verdict within an hour (241 lone pushes in the last 7 days, median 42 min)
  • Going faster ? (Michael)
    • new Mac Minis … (Adria)
      • Cypress is working well – new combined job which is 30 minutes …
      • had a lighthouse job, and a main one
        • merged these - the lighthouse tests which run in parallel
        • with more parallel cypress tests,
        • and fewer builds.
    • Mohit is moving cypress → Mocha tests. (Caolan)
      • Concerned wrt. the adding of cypress tests – lots coming in
      • We should be adding Mocha tests instead …
    • We had this problem with UI Tests in the past (Miklos)
      • good to use cypress tests for UI changes and go with unit/mocha tests otherwise if possible
    • AI: get measurements & proposal on ordering new Mac Minis by next week (Adria)
  • Almost written up the blog post on CI speedups – needs to add Wilson (Adria)
Crash testing (Caolan)
  • 2026-11-25
    • box up, new crashtesting script test in progress
    • lots of space + RAM – looks great …
    • new coolwsd based script to be used on the giant set.
    • AI: write up a big thank-you developer blog with the background of Adfinis’ contribution – and links to the other good things they’ve done & funded (Caolan)
  • 2026-11-18
    • box down for recommissioning
TTT talks
What’s cooking
  • Regina
    • ongoing work in smartart testing
    • need to solve build problems first: https://forum.collaboraonline.com/t/debug-build-of-engine-breaks-in-libjpeg-turbo/5247/3
      • make clean – now it can’t get a build again.
      • -Werror – could it be the problem ?
      • Problem looks specific to NASM
    • Hopefully Tor’s hint helps from this morning (Thorsten)
    • meta-problem: way too many ways to build on Windows (Michael S)
    • Each of the build approaches works (Andras)
      • on CI we use cygwin + WSL still – for older branches work
      • locally we use MSYS build system – which also works – for Balazs / Tor
      • Documentation suggests MSYS (Miklos)
    • Can we get the config.log ? (Caolan)
      • its in the forum (Andras)
    • **AI: **ask Mike K to have a screenshare with Regina to fix it (Miklos)
    • We have nightly build of CODA that has this in them (Michael)
      • yes tried, but doesn’t help with patch review (Regina)
  • Szymon
    • out.
  • Stephan
  • Caolan
  • Adrià
    • Crashtesting box setup
    • MacOS app wdio testing – infra setup
  • Miklos
  • Michael S
    • updated 3 externals
    • -fno-strict-aliasing https://gerrit.collaboraoffice.com/c/online/+/22068
    • inflated curl CVE severities from CISA-ADP via grype
      • seemingly they bump lots of severities to critical –
        when eg. curl themselves doesn’t think so
      • hoping to solve this via VEX annotations
  • Michael M
    • testing things, code review.
  • Quikee
    • out.
  • Kohei
    • not around.
  • Andras
    • SBOM for CODA
    • Quarantine behaviour (in a lot of cases nothing is in the quarantine after a crash, the patch set changes this, we save before open)
      • a performance hit of copying the file before we open every file ? (Michael)
      • copied it when we saved it first previously … (Andras)
      • Wonder if we could rescue this from the jail instead on crash ? (Michael)
  • Thorsten
    • code reviews & a few backports
    • testing the heck out of the colab feature …
