COOL UX-UI Design meeting minutes: 2026-04-16
UX-UI Refresh Team meetings
| Project | Sign in to Master latest-features-2026-02.docx |
| Video Call | Jitsi Meet |
| Forum | Development or a new category? |
2026-04-16
Minutes
  • Present: Andreas kainz, Heiko, Banobe, Bayram, Sahil, Pedro, Szymon, Mohit, Darshan, Rashesh, Ivana
Ivana
Heiko
Andreas K
  • Calc: Icon needed for the new Notes
  • Icons around the Mike K.
  • AI(Pedro) To reply to the git issue (Andreas prefers the first option of each batch)
  • AI(Pedro) to create a follow up issue to address behaviour and indicators, tooltips
Sahil
  • X11 → Wayland migration, everything works now.
  • Wayland supports multiple displays with different display scaling
  • Investigated dynamic zoom on a scaled up display (it works, but we can do better)
  • Comments can become under sidebar → !
  • DOING
    • dynamic-zoom: add dynamic zoom to impress (fixing CI)
    • Adding controls for default document level behavior
    • Investigated, tested prototypes with opencloud, it doesn’t have options dialog
    • AI: I need to setup nextcloud to make further progress here.
Banobe
  • Now: Restrict Find and replace dialog in view mode (calc and impress)
  • In core we only have readonly mode. So fix is to be implemented online for viewmode
  • However when we click Find, core send an update to the DOM and this enables the Replace button currently fixing this
  • Next: Write tests for Statusbar configuration menu toggle
  • Next: Writer – Low visibility on hover state in comment menu
Szymon
  • Now: Styles visibility filter for DOCX file format
  • It’s from properties saved inside file (show used in this document / all, order)
  • Will need: where to put UI? (you can start thinking about it)
  • Szymon: Possible to filter standard styles so you can create a template file that has in the top your custom styles. Example: Company creates styles following the brand guidelines → filter those styles in the notebookbar.
  • Andreas:
Rashesh
  • AI Assistant
    • Adding icons created by Ivana
    • Updated error marker
    • Where do we want this “AI Assistant” button?
    • Right now its in View tab
  • Thoughts about the chat bubble colours?
Mohit
Bayram
  • (Closed) – A11y Writer: Add labels to sidebar - checkboxes
  • (In progress) - A11y Calc: Manage names: deleting last defined name defocuses dialog
  • Reported bugs:
    • Writer: “Zoom to Fit Page” button needs second click to make the doc fit to page #15536
    • Writer: Under “Position and Size” → “Flip” icons are mis-aligned #15389
    • Writer: Selecting “keep ratio” checkbox should change the “unlock” icon to “lock” icon #15412
