COOL UX-UI Design meeting minutes: 2026-05-28
  • Present: Pedro, Sahil, Mohit, Ivana, Darshan, Szymon, Banobe, Shardul
  • Ruler
    • Ivana: Ruler https://github.com/CollaboraOnline/online/issues/15776
      • Context and discussion: let’s go with Ivana’s last suggestion
    • Development plan? (hear Szymon’s opinion, cc Darshan)
      • Change mouse cursors on hover
      • Change indicator SVG icons for the new ones
      • Add different states so we can change the icon on hover
      • Do you think it will be harder to have multiple tooltips visible at the same time (3) and live updating with the value while dragging?
        • Szymon: Currently it seems we hide all with the exception of one → but it should be ok
        • What about the live updating – as in update the values in the tooltips and changing the drawn line (but not live updating the document) – performance-wise?
          • Szymon: It should be fine since it’s mostly cosmetic changes. In the future, we should perhaps think about the possibility of converting the ruler into a canvas section → this would give a better frame rate (read HTML back and forth vs. Canvas).
      • Darshan: Tab stops, do they work? Do we have a different icon for it? What we have currently:
        • We do have marks that appear on double-click
        • We also have a right-click menu on the ruler that shows a tooltip that is actually a button → allows to insert/remove tab stop
        • Pedro: suggestion on having a dedicated button on the left
          • Darshan: Maybe it would be better to, as a first step, simply add another tooltip that appears anywhere in the empty ruler, something along these lines: “Double-click to insert a tab stop. Right-click for more options.”
          • Pedro: Yes, that is a better first step, and then we will see if we need to go further.
            • Maybe double-clicking on an existing tab stop or dragging it outside of the ruler should remove it. → Postpone anything around this, as we might need to double-check behavior on consequent tab stops.
  • Icon blueprint
  • NeedsUXEval
    • Removed label from NB Table Tab with Design previews and commands from the sidebar #15828 to know that it was answered, but we can discuss here.
      • Pedro to file task on having 2 contextual tabs visible (one that the user is redirected to)
    • Autofilter – had to revert resize (perf regression due to complex layouting with hundreds of entries) (Szymon)
      • We can rework that popup to simplify (.ui in core), ideas?
      • We grow down-right, weird when buttons are in that corner (OK, Cancel)
      • See picture below when I moved buttons up; maybe we can put them in a single row? And only “Apply”, no “Cancel” (Szymon)
      • Pedro: No, better do don’t do that. We should add a resizer as long as it doesn’t affect performance. We should probably not use a tree and instead use something simple, such as a simple HTML list or table → Pedro to create a task
  • Slide Sections:
    • Should a second click in the section header de-select the slides?
    • Need icons for Expand All & Collapse All, and Remove Section & Slides
  • Tasks
    • Icons in need of work
      • Insert → Smart Picker
      • Format → Theme
      • Help → Latest Updates
      • Right-click context menu: List right arrow is unreadable on mouseover
      • Maybe the Help → Accessibility Check could be improved to better signify that this is not a generic accessibility dialog/settings but it’s specifically checking the document
    • Fix odd break in References tab: references-zoterosetdocprefs-break
Newly created issues based on the discussion:
