Couldn't reset back to original after applying ascending sort in collabora online
Hello friends, I am using Collabora Online with the Pydio Cells Document Management tool. I selected a column and applied a sort on the column. I couldn’t find a reset option to bring it back to the original order. Is there any option to reverse the sort?
Thank you.
Unfortunately, once you apply a sort in Collabora Online, there’s currently no built-in option to revert the sheet to its original order. Sorting rearranges the rows in place, and unless you had an unsorted copy (for example, before saving or in another sheet), the original order can’t be automatically restored.
If this feature would be useful, you can open a feature request on our GitHub tracker:
GitHub · Where software is built
Hello, this has been fixed! We now support sheet views. This allows to have different views per sheet allowing each user to have a different sorting. To revert to the original sorting simply switch the view to the default (shared) view.
