I have never really had an issues with upgrading. However this time there is a dependency issue
coolwsd coolwsd : Depends: libgcc-s1 (>= 4.8)
Has anyone run into this problem?
This is debian on a virtualmin install
The dependency issue you’re encountering with coolwsd on Debian 10 Buster is related to the package libgcc-s1, which is not available in the default Debian 10 repositories. This package was introduced in later versions of Debian (starting with Debian 11 Bullseye). When trying to upgrade coolwsd, the package manager is unable to satisfy this dependency because it doesn’t exist in Debian 10’s repositories.
Here are a few potential solutions:
libgcc-s1 is available. This would resolve the dependency issue and allow you to install or upgrade coolwsd without problems.sources.list to point to Bullseye repositories and then running the upgrade process. This is a significant change, so ensure you have backups and that your environment is compatible with Debian 11.libgcc-s1libgcc-s1 package by downloading it from the Debian 11 repositories or a trusted third-party source. However, this approach can lead to potential stability issues, as it introduces a package from a different Debian version, which might have further dependencies that are not present or compatible with your current setup.Thanks,
