Hi all:
I’m trying to install on a Raspbian 10 machine. I followed the instructions for the native Linux install and received the following after a sudo apt install coolwsd code-brand command: Package coolwsd is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Package ‘coolwsd’ has no installation candidate
I tried it for both the Debian 10 and 11 repositories
Right, those repositories only contain x64 packages.
For the time being the only ARM packages are for Ubuntu 18.04:
Alternatively, if you have set up Nextcloud on the Pi, you could try the Collabora Online - Built-in CODE Server (ARM64) app.
And FYI, you need a 64-bit OS.
Thanks for the quick reply.
The 18.04 release isn’t going to work for me. It’s just too far back in the life cycle. The built-in sounds like it may be a possibility, although they report it to be slower and when they report it to be slower it generally means it’s s l o w e r. Ha. I also seem to recall that I tried it awhile back and it crashed my entire nextcloud install (and yes I’m running 64 bit).
I’ll have to think about this one for a while, but thanks.
If I go for the built-in code server does it require open access to the internet? My topology right now is that I use a reverse proxy for my Nextcloud instance.
Thanks.
