i’ve installed CODE on debian 10 but i’m not getting it started. It fails with
File not found: /etc/loolwsd/ca-chain.cert.pem
How can i disable SSL in loolwsd.xml?
loolconfig set ssl.enable false
doesn’t work. It gives “No property, “ssl.enable”, found in config file.”
Best regards
blink182
Thank you very much. But that didn’t work out for me.
The problem is that the CODE server is not reachable permamently via https. It seems it runs for a few seconds and then shuts down. Connections via Nextcloud always fail.
I used configuration no.2 from Setting up Nginx reverse proxy - Collabora Office and Collabora Online and set up nginx with a Let’s Encrypt certificate.
When i use
wget http://admin:mypass@locahost:9980
on the server i can access the admin interface properly.
Any hints?
