Can't get CODE started (without SSL)
Ubuntu 24.04.2 LTS
CoolWSD: 24.04.13.2
Install source: https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-deb
Problem description:
During startup using “sudo systemctl restart coolwsd” I am running into the following error:
Failed to initialize COOLWSD: File not found: /etc/coolwsd/ca-chain.cert.pem
I disabled all requirements (in coolwsd.xml) to need SSL (and even created an empty file with this name although it should not be needed).
Did i miss anything? It is my intention to run it with SSL eventually.
Any steps to help would be very usefull. If you need more information please let me know.
I see that someone else had the exact same problem but I cannot find what the user has fixed. 24.04.12.2-1 update broke my installation (follow-up) - #3 by vincen
Ok a fix in the coolwsd.xml file fixed it, but now NextCloud only wants to connect using SSL. Is there a way to disable this until i have everything setup properly ? I just want to test for now.
I setup server_name properly but you can’t use http:// there. Can i overwrite the protocol used to HTTP to WOPI only?
