ERR unknown UI default's component UITheme + WRN The systemplate directory is read-only
Hello everyone,
I have some errors in my logs that I don’t understand but which are not blocking.
wsd-00001-00037 2023-07-30 12:34:07.480936 +0200 [ websrv_poll ] ERR unknown UI default’s component UITheme| wsd/FileServerUtil.cpp:99
frk-00032-00032 2023-07-30 12:34:07.707183 +0200 [ forkit ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/hosts] is out-of-date. Will have to copy sysTemplate to jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:524
I checked the permissions on the directory which seems correct to me. How to correct this case?
drwxr-xr-x 11 root root 4096 Jul 25 18:13 systemplate
thank you in advance for your help.
Hey @nonofr91,
Welcome to the forum and thanks for asking the question.
Did any of the instructions here help?
And, if possible, can we get a little more info on:
  • What OS are you on?
  • How did you install Collabora Online?
  • Which version/s you are running?
    • In Collabora Online, in Help > About, a little copy button exists too.
Thanks. :slight_smile:
Good morning,
I run the command in a bash docker console:
coolconfig update-system-template
the result:
cool@8fb612d96292:/$ coolconfig update-system-template
Running the following command:
coolwsd-systemplate-setup /opt/cool/systemplate /opt/collaboraoffice >/dev/null 2>&1
But I still have the same problem.
For my installation here it is in its entirety even if only a part is useful:
I have esxi 7.3 with a VM with OMV 6 installed on it. I’m using docker 2.18.4 with collabora/code image
my stack:
version: “3”
collaborated:
image:collaboration/code:latest
container_name: collaborate
restart: unless-stopped
cap_add:
- MKNOD
   - domain=xxx.duckdns.org:443
   - username=tttt
   - password=jjjjj
   - TZ=Europe/Paris #Change Time Zone if needed
   - aliasgroup1=https://yyy.fr
   - aliasgroup2=https://xxx.duckdns.org
   - 9980:9980
same problem here. latest Docker deployment setup according to newest docu. Collabora Server doesnt work anymore with nextcloud
Hi, any news here ?
I can’t make my collabora work properly.
I need to click many times to the file before ti works
