Since the upgrade from collabora 21.x to 22.05.9, we encounter some errors while saving documents. Here are the most obvious message I get from the logs:
kit-06841-00042 2023-01-31 13:27:50.718848 +0000 [ kitbroker_0b7 ] ERR ToMaster-1d45: CALLBACK_ERROR: { "classification": "error", "cmd": "save", "kind": "io", "code": 770, "message": ""}| kit/ChildSession.cpp:2976
kit-06841-00042 2023-01-31 13:19:25.098385 +0000 [ kitbroker_0b7 ] ERR ToMaster-1d45: CALLBACK_ERROR: { "classification": "error", "cmd": "save", "kind": "io", "code": 770, "message": ""
kit-06841-00042 2023-01-31 13:19:25.098447 +0000 [ kitbroker_0b7 ] ERR ToMaster-1d45: CALLBACK_ERROR: {
"code": "0x507(Error Area:Io Class:Access Code:7)",
"kind": "",
"cmd": "",
"message": "Object not accessible.\nThe object cannot be accessed\ndue to insufficient user rights."
wsd-00001-06869 2023-01-31 13:28:41.152516 +0000 [ docbroker_0b7 ] ERR Failed to store the document and reached maximum retry count of 5. Giving up. The document should be recoverable from the quarantine. Save failures: 21, Upload failures: 0| wsd/DocumentBroker.cpp:439
wsd-00001-06869 2023-01-31 13:28:41.153208 +0000 [ docbroker_0b7 ] WRN DocBroker [https://chill.vendee.fr:443/wopi/files/d7bbef9f-3470-4a78-ab0b-02a77803ef28 stopped although flagged as modified: Broker: https://xxxxx:443/wopi/files/d7bbef9f-3470-4a78-ab0b-02a77803ef28 pid: 6841 has live sessions
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: loaded in: 1106ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: child PID: 6841
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: sent: 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: recv: 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: jail id: zx5DQuxMQPsE5KtH
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: filename: doc_63d2b2ad5b3881.54063868_odt.odt
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: public uri: https://xxxxxx.fr/wopi/files/d7bbef9f-3470-4a78-ab0b-02a77803ef28?access_token=eyJ....obfuscated...3HTAefyA&access_token_ttl=1675206732000
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: jailed uri: file:///tmp/user/docs/zx5DQuxMQPsE5KtH/doc_63d2b2ad5b3881.54063868_odt.odt
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: doc key: https://xxxxx:443/wopi/files/d7bbef9f-3470-4a78-ab0b-02a77803ef28
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: doc id: 0b7
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: num sessions: 1
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: thread start: Tue Jan 31 13:12.612 2023 (986s 540ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: stop: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: closeReason: storefailed
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: modified?: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: possibly-modified: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: canSave: CanSave::Yes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: canUpload: CanUpload::Yes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isStorageOutdated: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: needToUpload: NeedToUpload::No
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: lastActivityTime: Tue Jan 31 13:28.673 2023 (1s 479ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: haveActivityAfterSaveRequest: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: lastModifyActivityTime: Tue Jan 31 13:28.673 2023 (1s 479ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: haveModifyActivityAfterSaveRequest: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isViewFileExtension: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: idle time: 1
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: cursor X: 1701, Y: 12979, W:0, H: 150
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: DocumentState:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: doc state: Status::Live
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: doc activity: Activity::None
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: doc loaded: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: interactive: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: close requested: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: unload requested: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: disconnected from kit: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: SaveManager:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isSaving now: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: idle-save enabled: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: idle-save interval: 30000ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: auto-save enabled: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: auto-save interval: 300000ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: check interval: 30000ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last auto-save check time: Tue Jan 31 13:28.143 2023 (0s 9ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: auto-save check needed: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last save request: Tue Jan 31 13:28.143 2023 (0s 9ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last save response: Tue Jan 31 13:28.151 2023 (0s 1ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last save duration: 8ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: min time between saves: 500ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: file last modified time: Thu Jan 01 00:00.000 1970 (1675171721s 152ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: saving-timeout: 5s
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last save timed-out: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last save successful: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: save failure count: 21
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: StorageManager:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isUploading now: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last upload request time: Tue Jan 31 13:12.612 2023 (986s 540ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last upload response time: Tue Jan 31 13:12.612 2023 (986s 540ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last upload duration: 0ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: min time between uploads: 5000ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last modified time (on server): 2023-01-31T11:36:46+00:00
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: file last modified: Tue Jan 31 13:12.434 2023 (985s 718ms ago)
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: last upload was successful: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: upload failure count: 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: Current StorageAttributes:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: forced: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: user-modified: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: auto-save: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: exit-save: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: extended-data:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: Next StorageAttributes:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: user-modified: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: exit-save: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: TileCache:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: num: 29 size: 101678 bytes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 614 25 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=13652 tileposy=3413 tilewidth=3413 tileheight=3413 oldwid=0 wid=614 ver=720 imgsize=26 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 390 25 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=13652 tileposy=6826 tilewidth=3413 tileheight=3413 oldwid=0 wid=390 ver=472 imgsize=26 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 376 25 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=13652 tileposy=10239 tilewidth=3413 tileheight=3413 oldwid=0 wid=376 ver=477 imgsize=26 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 359 104 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=0 tileposy=17065 tilewidth=3413 tileheight=3413 oldwid=0 wid=359 ver=448 imgsize=105 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 136 4685 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=0 tileposy=13652 tilewidth=3413 tileheight=3413 oldwid=0 wid=136 ver=224 imgsize=3661 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 361 46 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=6826 tileposy=17065 tilewidth=3413 tileheight=3413 oldwid=0 wid=361 ver=450 imgsize=47 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 6 9833 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=3413 tileposy=3413 tilewidth=3413 tileheight=3413 oldwid=0 wid=6 ver=22 imgsize=10637 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 137 1763 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=3413 tileposy=13652 tilewidth=3413 tileheight=3413 oldwid=0 wid=137 ver=225 imgsize=1764 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 1 2162 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=0 tileposy=0 tilewidth=3413 tileheight=3413 oldwid=0 wid=1 ver=17 imgsize=2163 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 11 25 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=6826 tileposy=6826 tilewidth=3413 tileheight=3413 oldwid=0 wid=11 ver=27 imgsize=26 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 16 55 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=10239 tileposy=10239 tilewidth=3413 tileheight=3413 oldwid=0 wid=16 ver=32 imgsize=56 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 360 46 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=3413 tileposy=17065 tilewidth=3413 tileheight=3413 oldwid=0 wid=360 ver=449 imgsize=47 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 5 15336 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=0 tileposy=3413 tilewidth=3413 tileheight=3413 oldwid=0 wid=5 ver=21 imgsize=15657 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 10 4873 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=3413 tileposy=6826 tilewidth=3413 tileheight=3413 oldwid=0 wid=10 ver=26 imgsize=3655 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 15 8049 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=6826 tileposy=10239 tilewidth=3413 tileheight=3413 oldwid=0 wid=15 ver=31 imgsize=8065 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 380 25 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=13652 tileposy=13652 tilewidth=3413 tileheight=3413 oldwid=0 wid=380 ver=482 imgsize=26 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 4 209 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=10239 tileposy=0 tilewidth=3413 tileheight=3413 oldwid=0 wid=4 ver=20 imgsize=210 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 138 25 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=6826 tileposy=13652 tilewidth=3413 tileheight=3413 oldwid=0 wid=138 ver=226 imgsize=26 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 2 391 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=3413 tileposy=0 tilewidth=3413 tileheight=3413 oldwid=0 wid=2 ver=18 imgsize=392 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 362 116 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=10239 tileposy=17065 tilewidth=3413 tileheight=3413 oldwid=0 wid=362 ver=451 imgsize=117 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 7 11690 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=6826 tileposy=3413 tilewidth=3413 tileheight=3413 oldwid=0 wid=7 ver=23 imgsize=11343 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 12 55 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=10239 tileposy=6826 tilewidth=3413 tileheight=3413 oldwid=0 wid=12 ver=28 imgsize=56 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 139 55 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=10239 tileposy=13652 tilewidth=3413 tileheight=3413 oldwid=0 wid=139 ver=227 imgsize=56 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 3 1041 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=6826 tileposy=0 tilewidth=3413 tileheight=3413 oldwid=0 wid=3 ver=19 imgsize=1042 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 385 25 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=13652 tileposy=17065 tilewidth=3413 tileheight=3413 oldwid=0 wid=385 ver=487 imgsize=26 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 8 323 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=10239 tileposy=3413 tilewidth=3413 tileheight=3413 oldwid=0 wid=8 ver=24 imgsize=324 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 9 17343 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=0 tileposy=6826 tilewidth=3413 tileheight=3413 oldwid=0 wid=9 ver=25 imgsize=13148 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 14 8753 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=3413 tileposy=10239 tilewidth=3413 tileheight=3413 oldwid=0 wid=14 ver=30 imgsize=8879 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 13 12371 bytes ' nviewid=0 part=0 width=256 height=256 tileposx=0 tileposy=10239 tilewidth=3413 tileheight=3413 oldwid=0 wid=13 ver=29 imgsize=11686 keyframe
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: stream cache: 0 num: 0 size: 0 bytes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: stream cache: 1 num: 0 size: 0 bytes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: stream cache: 2 num: 2 size: 116926 bytes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: .uno:CharFontName 110168 bytes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: .uno:StyleApply 6758 bytes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: tiles being rendered 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: SocketPoll:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: Poll [1] - wakeup r: 66 w: 74
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: fd events rsize wsize
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: 93 1 process 0 0 r: 1895029 w: 104447 uds-to-pid-6841 alive 0.247ms
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: Sessions [1]:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: id: 1d45
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: name: ToClient-1d45
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: disconnected: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isActive: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isCloseFrame: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isWritable: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isReadOnly: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isAllowChangeComments: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isEditable: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: docURL: https%3A%2F%2Fxxxxxxxxr%2Fwopi%2Ffiles%2Fd7bbef9f-3470-4a78-ab0b-02a77803ef28
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: jailedFilePath:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: docPwd:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: haveDocPwd: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isDocPwdProtected: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: DocOptions:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: userId: xxxx
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: userName: xxxxxxx
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: lang:
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isLive: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isViewLoaded: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isDocumentOwner: false
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: state: SessionState::LIVE
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: keyEvents: 42
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: clientSelectedPart: 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: tile size Pixel: 256x256
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: tile size Twips: 3413x3413
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: kit ViewId: 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: our URL (un-trusted): https://xxxxxx
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: isTextDocument: true
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: clipboardKeys[0]: b3780f37917a8d82
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: clipboardKeys[1]: 6b9f9df231f44622
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: clip sockets: 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: proxy access::
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: clientSelectedMode: 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: sent/keystroke: 0bytes
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: queue size 0
Jan 31 13:28:41 kaloupile b3dfb1a66783[18127]: | wsd/DocumentBroker.cpp:549
Jan 31 13:28:43 kaloupile b3dfb1a66783[18127]: Forced Exit with code: 70
We run collabora in a docker image. It is run as privileged container. Our docker-compose file:
version: '3.6'
app:
image: our-repository.com/collabora/online:22.05.9-3
restart: always
- "9980:9980"
- "SLEEPFORDEBUGGER=0"
- "aliasgroup1=https://example\\.com"
cap_add:
- MKNOD
privileged: true
Our image is built using a secret_key from collabora online’s portal (we use drone and ci/cd for building this image).
As I understand, the process is not able to save the document into the jail, at /tmp/users/docs.
I do not find other peoples having this error on this forum.
