Hello, I have been having problems integrating Collabora Online with Nextcloud, the following happens I have the Collabora Online Server installed when I link it with Nextcloud, no problem, it sends me the legend Collabora Online server is recheable.
Currently I’ve following configuration to nextcloud:
HAProxy SSL → (inlets tunnel 8000 → 80) → HAProxy Http → Nextcloud server
The same configuration to Collabora:
HAProxy SSL → (inlets tunnel 8000 → 80) → HAProxy Http → Collabora server
So, I try with this configuration too:
HAProxy SSL → (inlets tunnel 8000 → 80) → HAProxy Http → Nginx Reverse Proxy (same server) → Collabora server
The problem is when I want to create a document or open a document with the odt extension is when it is stunned and practically blank, this could be because it is happening.
The config is following:
HA Proxy SSL
frontend http-in
mode http
bind *:80
bind :443 ssl crt /etc/ssl/certs/web-certs.pem
option httplog
redirect scheme https if !{ ssl_fc }
default_backend inlets
backend inlets
mode http
stick-table type ip size 200k expire 30m
stick on src
server haproxy_tunnel 127.0.0.1:8000 check
HA Proxy Http
frontend http-in
mode http
bind :80
option httplog
acl cloud hdr(host) -i cloud.server.org
acl collabora hdr(host) -i collabora.server.org
use_backend ha_nextcloud if cloud
use_backend collabora_back if collabora
mode http
balance roundrobin
stick on src
server node1 10.1.1.29:80 check
timeout tunnel 3600s
mode http
server collabora_node1 10.1.1.12:9980 check
