Now that I’ve finally managed to build a “Collabora Office classic” build, the next problem has cropped up. My patch requires a change-id. How to generate it?
The command scp -p -P 29418 regina-henschel@gerrit.collaboraoffice.com:hooks/commit-msg .git/hooks/ does not work. I get the message
subsystem request failed on channel 0
scp: Connection closed
I have used the command in Git Bash in folder engine. Using it in folder online does neither work.
Since OpenSSH 9.0, scp uses the SFTP protocol by default instead of the old “legacy SCP” protocol. Gerrit’s built-in SSH server does not implement an SFTP subsystem, so when your modern scp asks for it, the server refuses:
Git Bash ships a recent OpenSSH, which is why you hit this.
Fix 1: force the legacy protocol with -O
Add the -O flag (capital letter O, for “old protocol”):
