Impossible to disable auto linking
If your text is the actual link in a cell it’s impossible to remove the auto linking. There’s also no options to disable auto linking feature.
Pressing this button doesn’t remove the link.
Even if I tried not using a link and use a word instead, the remove link button doesn’t work either.
This seems like a bug report but I’m not sure where to report it.
Hey @SafeLamp. Welcome to the forum + thanks for the report. :slight_smile:
I confirm this bug. Also looks like the “Copy link location” button doesn’t work either!
So, in Calc, after clicking on a URL and getting the popup.
You then can click on:
  • The URL works.
    • YES → Get the “External link” popup + sends you to URL.
  • “Copy link location”
    • NO.
  • “Edit Link”
    • YES → get the “Hyperlink” popup.
  • “Remove Link”
    • NO.
Would also help to get your exact:
  • Help > About info too!
Here’s mine:
COOLWSD version: 24.04.4.1 (git hash: bada0174)
LOKit version: Collabora Office 24.04.4.1 (git hash: ddb454b)
Served by: Linux Mint 21.3
Server ID: a54351db
The “Collabora Online” Github is where bug reports go. :slight_smile:
Do you have an account there? (If not, then I can post it there too if needed.)
If you want to remove hyperlinks in Calc, you can also remove it manually by:
Method 1: “Clear Direct Formatting” button in Home tab
Method 2: Right-Click
  • Highlight the cell.
  • Right-Click > Clear Direct Formatting
Would also help to get your exact: Help > About info too!
COOLWSD version: 24.04.3.1 (git hash: 594b605 (E))
LOKit version: Collabora Office 24.04.3.1 (git hash: 31b6e2c)
Served by: Debian GNU/Linux 12 (bookworm)
Thanks for the provided solutions. I do have an account on Github where I added this issue discussed here. I took the liberty to use your write up which brought up more issues. Hope that’s fine and thank you for helping!
