I’ve been maintaining my installation for a few years via the CODE-deb/ aka CODE-ubuntu2204/ as packages. I don’t see 26.04 has arrived there yet, although I believe the Docker installation method has them. Is there a plan for supporting the packages, or should I try to bite the bullet and configure with Docker? I have several Nextcloud instances served by on CODE instance, and so I need to make sure I curate the groups feature, rather than first served.
Thanks!
