Is there yet a IOS build for CODE 2604 available in Testflight? After 2504 build expited that was not updated to 2604 automatically so is that a new link to register?
Kind rebards, Sebastiaan
Hi Sebastian,
No there’s not an iOS build for 26.04 in Testflight yet.
I’m really sorry about the delay here, I’ve been off work for the past few months for personal reasons and up until I left was the sole developer releasing mobile. Thanks for being patient and bearing-with.
I’m back now and expect to be able to get some 26.04 Testflight builds for you by the end of next week. As soon as those are published, Apple will let you know and you’ll be able to update to 26.04. You won’t need to join a new Testflight link, you should see the builds on the same beta as we used for 25.04.
To avoid this happening again, as well as to help us improve more of mobile more-quickly, @karthik and @celestial-starfruit are joining me in working on the mobile apps. This means that, even if I’m not able to work again, we should still be able to do updates like this in a timely manner in the future.
Thanks again,
Best,
Skyler
@Minion3665 no problem! Good news that you now get the additional power to support you in the dev proccess:)
Kind regards, Sebastiaan
Hi Sebastiaan,
Just a little update for you - I’ve made a 26.04 Testflight build and it’s currently being reviewed by Apple. They’re usually fairly quick at reviewing test builds - normally under a day although I have rarely seen it be as much as 2 days. As soon as that’s reviewed it’ll be published for you to try out!
Best,
Skyler
Thx, the App is updated! We can continue testing ![]()
