Hello everyone,
I’m currently trying CODE and I was wondering if it would be possible to integrate libreoffice python extensions with Collabora Online. I haven’t found anything about this topic in the SDK documentation but there were some posts here in this forum that that talked about it, like in the following post for example:
I have tried to add a python extension that adds a sidebar and I added some adjustments to the code which then worked perfectly well, but if I try to launch the same build In docker the extension wouldn’t work for some reason. The logs didn’t indicate any error.
I would like to know if it is even possible to integrate such extensions in the first place, if it’s not possible, I would appreciate if someone would tell me how would it be possible to add a sidebar otherwise ?
