I want to introduce a “Length” unit type as the standard unit type for length used everywhere a logical unit is currently needed. The type always stores values as EMU units internally, is strongly typed, and has integrated conversions to and from other units (hmm, twips, pt, …). Currently the type uses sal_Int64, where the value represents EMUs, which can represent 100th of mm and twips as integers. There are also defined literals for units, which make it possible to express which unit you want directly as a literal: 1_px, 10_emu, 20_hmm. You can also mix them when calculating, e.g. auto width = 1_hmm + 2_twip. Please read more about it in the [1] commit message, LengthBase.hxx, and the tests (how it’s used).
In addition, there are the types Tuple2DL, Size2DL, and Range2DL that use the Length type, but are essentially similar to B2DTuple, B2DSize and B2DRange (they share the same template classes).
Plan to integrate:
I’ve been trying to integrate this into svx and other modules for quite some time, but couldn’t find the right approach to do it step-wise without blowing up the complexity. Now I think I have a plan that can work. The main issue is that in svx, SdrObjects can work with multiple units, but technically they work in two - either 100th mm (Impress, Draw, Calc) or twips (Writer). This is a problem for integration, because if we want to do a bottom-up replacement, we would need to know what the unit-less values represent (hmm or twips), and we don’t know that. I tried it and it started to get too complex.
Another choice is to go top-down and convert Writer first, so we eliminate one possibility. This is the direction I’m going now. It is rather easier to do the conversion in Writer because we already have the SwTwips type there - so we can just replace SwTwips with gfx::Length. One idea was to integrate Length into SwTwips, but that didn’t work as I expected, so we have to convert the usages one by one.
In [2] I started changing this, and in [3] it showed the advantage of this approach by eliminating round-trip rounding errors. The issue is that the properties use 100th mm as the standard unit, and converting it to twips and back (export) produces rounding errors. Using Length instead eliminates that, but we need to introduce new properties (HoriOrientPositionEMU instead of HoriOrientPosition).
Before continuing and start integrating this, I would like some feedback on whether this is an approach we should take, or what you would change.
[1] https://gerrit.collaboraoffice.com/c/online/+/3955
