I find that Navigator and Navigation are used inconsistently.
We call it the Navigator
And once it’s opened the panel is titled Navigation
Can’t it just be Navigation everywhere?
Hi @Stephan-P ,
Thanks for bringing up this topic!
I’ve created a GitHub issue to track this so we can have a more focused discussion with the community:
opened 07:05AM - 02 Nov 26 UTC
Easy Hack
26.04
### Describe the Bug
The command that opens the panel is called Navigator in th… e menus and the notebookbar. Once the
panel is open, its title reads Navigation. The two names for one feature are confusing, and
translators have to keep both.
### Steps to Reproduce
1. Open a Writer, Calc or Draw document.
2. Click View > Navigator (or the Navigator button).
3. Read the panel title.
### Expected Behavior
One name in both places.
### Actual Behavior
Button: Navigator. Panel title: Navigation. The panel's aria-label already says Navigator.
### Evidence from user feedback
- Forum (localization category): https://forum.collaboraonline.com/t/5191 (2026-11-01).
### Additional Context
In browser/src/control/Control.NavigatorPanel.ts the title is set with _('Navigation'), while
the aria-label and another label in the same file use _('Navigator'), and the notebookbar uses
_UNO('.uno:Navigator'). Using "Navigator" for the title would match the engine name.
Feel free to share your thoughts and ideas there.
Also, you’re very welcome to join our public UX/UI design calls, which take place every Thursday. It’s a great place to discuss design ideas and exchange feedback with the community:
Looking forward to hearing your thoughts!
Cheers,
