If you are getting the following error: Collabora Online is not setup yet. Click here... when using richdocuments app 3.7.x. Please make sure you update to 3.8.1 or 4.1.0.
Bug report opened:
opened 10:06AM - 21 Mar 21 UTC
closed 12:10PM - 05 May 21 UTC
**To Reproduce**
Steps to reproduce the behavior:
- Open a file, with Collabor… a Online running (to confirm all is fine at the beginning),
- Stop `loolwsd` service,
- Try opening a file again, it'll spin, then time out, feel free to go back right away, no need to wait for the timeout,
- Start `loolwsd` service again,
- Try opening a file again.
**Expected & buggy behavior**
After the last step, the file should open.
Instead there is an error: `Collabora Online is not setup yet. Click here...`
The admin has to get into the Settings, and click Save on the URL, then it works again.
Built-in CODE Server (richdocumentscode) triggers a similar bug after upgrade, the error message is different (a generic failure message), but opening files fails, and clicking Save in Settings fixes it.
## Server details
**Nextcloud version:**
20.0.8
**Version of the richdocuments app**
3.7.17
**Version of Collabora Online**
6.4.7
If you cannot update right now and as a temporary solution:
Click Save on the URL
Now you can open files
