Pasting in Collabora Office Calc
Hello. I’m used to paste same value in multiple cells at the same time. It works in LibreCalc by default, but in Collabora Calc I couldn’t find a way to do it. Right now paste works only on first selected cell. Thank you.
Installed testing version from flatpak on linux.
hi @Le0
Hi, I’m not fully sure about the exact limitation here, but based on what I could gathe
few things you could try:
  1. Use Fill → Down / Right
    Type the value in the first cell, then drag the fill handle or use Sheet → Fill Cells to copy the value across the selection.
  2. Check if multi-cell paste is tracked as a known issue
    The Flatpak testing build sometimes lacks features still under integration. If the above methods do not work, it might be a temporary limitation. You can also search or file an issue here:
    GitHub · Where software is built
Well, fill with dragging is working as intended. But cells not always next to each other. And I didn’t find “Sheet” panel with “Fill Cells” option.
I will look for issues then. Thanks
