Hi!
I added a second domain name for our nextcloud and want to redirect every traffic to the new domain.
It works fine, but collabora online doesn’t work if I do this. (doesn’t matter if I use the old or new domain-name in the nextcloud settings for collabora, but without the rewrite rule in the nginx.conf the old domain-name works well [the new one not])
I added the relevant part of my nginx.conf:
(secretdomain.de is only a placeholder)
upstream php-handler {
# server 127.0.0.1:9000;
server unix:/run/php/php7.4-fpm.sock;
server {
listen 80;
listen [::]:80;
server_name speicherwolke.secretdomain.de nextcloud.secretdomain.de;
# enforce https
return 301 https://$server_name$request_uri;
#return 301 https://speicherwolke.secretdomain$request_uri;
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name nextcloud.secretdomain.de;
rewrite ^ $scheme://speicherwolke.secretdomain.de$request_uri permanent;
#return 301 $scheme://speicherwolke.secretdomain.de$request_uri;
ssl_certificate /etc/letsencrypt/live/nextcloud.secretdomain.de/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/nextcloud.secretdomain.de/privkey.pem;
server {
listen 443 ssl;
# static files
location ^~ /loleaflet {
proxy_pass https://localhost:9980;
proxy_set_header Host $http_host;
# many other none relevant stuff here [...]
Does anyone have an idea where the problem is or even a solution?
Long greetings
Kevin
