shared ccache bits ...
Hi all,
  Been wrestling with trying to get a shared ccache between my (several) live work-directories to try to reduce CPU melting action.
  I got this far:
  https://gerrit.collaboraoffice.com/c/online/+/4416
  Tried with CCACHE_NODIRECT=true make - and got some encouraging matching hashes across different top-levels, but ... still no ccache hits; weird.
  For debugging:
  CCACHE_DEBUGDIR=/tmp/mono2-cc CCACHE_DEBUG=1 make
  Has the nice benefit of putting the .ccache-foo files in a single place that can be compared reasonably easily - but I still get:
[2026-06-13T08:16:10.375895 6471 ] Result key: eb03sg1nqsh4v1kqitssoq7aq23rs7l24
[2026-06-13T08:16:10.379477 6471 ] Stored eb03sg1nqsh4v1kqitssoq7aq23rs7l24 in local storage (...cache/ccache/e/b/03sg1nqsh4v1kqitssoq7aq23rs7l24R)
[2026-06-13T08:16:10.379614 6471 ] Result: cache_miss
[2026-06-13T08:16:10.379615 6471 ] Result: local_storage_miss
[2026-06-13T08:16:10.379615 6471 ] Result: local_storage_write
  I wonder - does anyone else have experience of trying to do this? of course ccache -s shows similar lack of hitting.
  I was thinking it may (may) help my local builds improve - it might help CI go faster.
  Thoughts ?
    Michael.
Locally I'm using multiple git worktrees of debugging versions and a
shared ccache cache apparently successfully.
I put all of those at the same level under the same dir. Call that
$repos
My config is:
ccache --set-config "base_dir=$repos"
ccache --set-config "hash_dir=false"
ccache --set-config "compiler_check=content"
so that gives me a ~/.config/ccache/ccache.conf of:
max_size = 50G
base_dir = /home/caolan/repos
hash_dir = false
compiler_check = content
For everything under that "repos" base_dir then ccache relative-izes
the build, so existing "monorepo-X" ccache entries can serve a new
"monorepo-Y" throwaway git worktree. The new "build" is then about 2
minutes for an up to date to date ccache
There's been some recent changes merged to make this work, concat-deps
and fix ups of "../../" style includes that otherwise defeat this, so
the repo has to be up to date or there are mysterious build failures.
wrt debugging: https://gerrit.collaboraoffice.com/c/online/+/3998 is
yet to be reviewed/merged to make the *debugging* of that build safe in
the face of a build using a ccache entry from a deleted worktree. With
that applied then gdb has to be launched from the root of the source
you want it to use for display (though this is scriptable in
~/.config/gdb/gdbinit so you don't have to think about it)
I've gotten a little bit carried away with this and have a cronjob that
builds a dedicated "clean" worktree nightly so the ccache should have
fresh "main" results in it if/when I rebase my personal worktrees.
  Ah - just trying to build that into the code itself :slight_smile:
  Yep - my machine goes from one and a half hours to four and a half minutes with this for all builds.
  I had to push a VPATH addition to the Makefile rules to ensure that 'make' in sub-directories didn't fall foul of the relative paths.
  So I think:
  Is ready for review there :slight_smile:
  The relative deps seem to need the VPATH.
  Looks sensible to me; +2
  Heh :slight_smile: seems even more 31337 to me; of course I only dip in and out of development; but sounds great.
  Thanks !
    Michael.
