is it possible to configure collabora so that when opening, the side shutter is closed?
Welcome @osimon : )
Yes there are two ways
- Via the integration side
SpreadsheetSidebar=falseorTextSidebar=falseorPresentationSidebar-false: Theming of Collabora Online — SDK https://sdk.collaboraonline.com/ documentation - For example you can close it by I managed to hide the sidebar by adding the following hidden input field into the iframe form:
<input name="ui_defaults" value="UIMode=notebookbar;TextSidebar=false" type="hidden"/>```
- The second way is by simply adjust the
loolwsd.xmlinside of<user_interface>(as seen bellow). However it seems we have currently a bug around that Issue#2510<user_interface> <mode type="string" desc="Controls the user interface style (classic|notebookbar)" default="classic">notebookbar</mode> <writer> <ruler type="bool" desc="Controls whether the ruler would be shown at the first load of the document." default="true">true</ruler> <statusbar type="bool" desc="Controls whether the statusbar would be shown at the first load of the document." default="true">true</statusbar> <sidebar type="bool" desc="Controls whether the sidebar would be shown at the first load of the document." default="true">false</sidebar> </writer> <spreadsheet> <sidebar type="bool" desc="Controls whether the sidebar would be shown at the first load of the document." default="true">false</sidebar> </spreadsheet> <presentation> <statusbar type="bool" desc="Controls whether the statusbar would be shown at the first load of the document." default="true">true</statusbar> <sidebar type="bool" desc="Controls whether the sidebar would be shown at the first load of the document." default="true">false</sidebar> </presentation> </user_interface>
also adding &ui_defaults=TextSidebar%3Dfalse to the end of the URL should do the same thing
